Am I being daft- Speedo drive
Ratty43
As per the topic really, during my recent clutch change I stupidly trapped the speedo cable between the bell housing and the engine (R380 & 300tdi). That resulted in the socket end of the speedo drive shearing (amazed it was the plastic gear that went). That didn't bother me too much as it's always read 10% over the actual speed so I had been intending to change it for a more accurate reading. With that in mind I bought a 20 tooth drive to replace the 22 tooth one that was in there thinking it would spin 10% faster correcting the speedo. Went out with the sat nav today and it now reads 20% over. Does this mean I've been daft (certainly seems so!) And need a 24 tooth drive instead? Thanks in advance.
Personally...I would buy a VDO speedo. They look better, you can see them at night and you can program them to be correct.
So... read what you wrote above. "...it's always read 10% over the actual speed..." then "... thinking it would spin 10% faster..." You seem to understand you purposely chose a gear to make the speedo spin faster, but you wanted it to spin slower in order to correct the speedo error. So, yes, more teeth equals speedo runs slower.
Bloody hell. I can't for the life of me see how I managed to be quite that thick. I'm off to sit in the corner. Cheers for that, it was one of those wood for the trees moments where I bought it knackered and the idea stuck.
my speedo seems to have an affliction to lasting any length of time,
although being a series xfer box and taller tyres and a 3.54 diff it pretty much reads in KPH what youre actually travelling in MPH lol ive never found evidence of correction for series speedo's though unfortunately
Mr Noisy, transfer box ratio won't make an iota of difference, as it reads the propshaft speed :)
Diff and tyres obviously will :)
yeah sorry dude, thanks for clarification, it was more explaining the fact that i have changed the diffs and the transfer ratio, to end up with the same overall ratio in high range but a different propshaft rpm for given road speed thus will need to mess about with speedo gears again :D
