lhd - rhd conversion
richardthestag
A mates 90 had an ambidextrous front axel, but Disco1 and RRC didn't, which is why the swivel is rare ish. I even tried France, but they want all they can get to change UK disco's to LHD! Dennis on Linden Engineering in Colarado had a few, so maybe he has other bits as well?
Unless you are going the other way, LHD to RHD, in which case, to be cheeky, do you want to swap two-arm swivel housings ^_^ (you might as well re-seal both side at once :blush: )
  • 2 weeks later...
  • 5 weeks later...
  • 2 weeks later...
The best option would be to buy a scrap 4 door classic of similar age to salvage parts (you don't say what age the left hooker 2 door is but I'm going to assume it's a later "CSK" style shell).
Wiring should stretch over to the new dash position.
If you have aircon then you might need to swap that over, along with all the stuff behind the dash for that, probably need new aircon pipes too.
