Defender gear selector
I have a defender 90 2.5 diesel which is difficult to select gears. It goes into gear fine but 2nd into 3rd is a bit tricky as the gears all seem really close. The guy I brought the vehicle off told me all it needed was a new gear selector which could be fitted from inside the vehicle by removing gear stick gator to gain access.
Does any one know if it's that simple.
  • 1 month later...
Hi only just round to having a look, the spring is ok but where it sits either side of the turret it's badly worn on the right hand side. When you but it in reverse the spring ends up sitting in a worn grove and not on the adjuster bolt. Do you think this would make gear selection difficult ????
