bedfontgn Posted April 10, 2014 Share Posted April 10, 2014 Hi folks, Might be easy but its got me stumped at the first hurdle. Outside: key turns normally, button goes up but door stays locked. No action on central locking Inside: no response to pull handle at all even when holding button up. All other locks ok albeit no c/l My first response is to take the panel off and have a look see but how do I get it off as the door is still locked and the seat is in the way TIA Quote Link to comment Share on other sites More sharing options...
Early90 Posted May 4, 2014 Share Posted May 4, 2014 You could try popping the top seal up to see if you can coat hanger the mechanism through he gap, not sure what you can see down through the gap though but will only take a minute to look. Failing that I think it means door card off, you should still be able to reach the screws and the rest pops off, then it`s coat hanger time. Quote Link to comment Share on other sites More sharing options...
