Bigant Posted April 20, 2014 Share Posted April 20, 2014 Hi Each time I run my series 2a 21/4 petrol the battery runs flat so I am assuming that there is an issue with the alternator, however the alternator was new when fitted and has done barely any mileage. Could there be something else that is faulty and preventing the alternator from passing a charge back to the battery? Ant help greatly appreciated. Regards Bigant Quote Link to comment Share on other sites More sharing options...
Pollywog Posted April 20, 2014 Share Posted April 20, 2014 Have you checked your wiring? Put a multimeter on the bettery with the engine off, and then again with the engine running, if it's all correct it should read about 14v when running. Also do you have anything fitted that could be draining the battery? Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted April 21, 2014 Share Posted April 21, 2014 As above - but is the battery any good? - they don't last forever! But first - is the belt tight? Then are the terminals still good? - clean? and properly fitted? Quote Link to comment Share on other sites More sharing options...
Bigant Posted April 21, 2014 Author Share Posted April 21, 2014 Hi I need to run a volt metre test for sure, as far as the battery its brand new and the belts seem all a OK. I can't remember what setting to opt for to run the voltmeter test, any suggestions? Bigant Quote Link to comment Share on other sites More sharing options...
Pollywog Posted April 21, 2014 Share Posted April 21, 2014 Funnily enough I had to test mine this afternoon to check my new split charge system was working, multimeter set to DCV 50x Quote Link to comment Share on other sites More sharing options...
jbs Posted April 22, 2014 Share Posted April 22, 2014 Have you got all of your earths connected to where they should be? John Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 22, 2014 Share Posted April 22, 2014 With ignition off, remove battery terminal, measure current (Amps) across the gap (if you're not familiar with how to use a multimeter, google it before blowing it up). Should be pretty much zero, if it's not you can play the game of unplugging things until it drops to zero, then the last thing you unplugged is the drain. Fortunately not very much electrical on a Series! Quote Link to comment Share on other sites More sharing options...
