neil3728 Posted May 5, 2014 Share Posted May 5, 2014 I am looking to install a 7 pin trailer socket in my e reg 110. I have got myself confused over the wiring, which seems to be in a real mess. I have found a set of 5 wires coming through a grommet in the back. White, green, yellow, red brown There is also a second set of 5 which seem to be separated from the rest, Green, red with green trace, brown with red trace White with black trace Black Struggling to work out what these wires are for and can any be used to wiring in my tow electrics. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
western Posted May 5, 2014 Share Posted May 5, 2014 2nd set look to be for rear wiper motor & heated rear screen wiring Green = ign controlled 12v feedred with green trace = rear wiper motorbrown with red trace = none shown at rear in 110 wiring diagram, brown/red is glowplug wiring on non tdi engined vehicleWhite with black trace = rear screen heaterBlack = standard earth wire colour on Land Rovers. trailer 7 core colours are all single colour wires red blue green white black yellow brown all explained here http://www.the12voltshop.co.uk/Shop/about-towing-electrics-1-plugs-and-sockets.html Quote Link to comment Share on other sites More sharing options...
neil3728 Posted May 5, 2014 Author Share Posted May 5, 2014 Okay thanks, that explains the 2nd set as I don't have a rear window. So wiring is surplus now. Quote Link to comment Share on other sites More sharing options...
neil3728 Posted May 6, 2014 Author Share Posted May 6, 2014 So should I am able to use these, wires as part of the trailer socket wiring. White, green,yellow,red brown and pick up the rest, from the other lights, as I would just need the black been the LH side light and blue been the fog light. Quote Link to comment Share on other sites More sharing options...
western Posted May 6, 2014 Share Posted May 6, 2014 only if the go to the existing socket colours as per this Pin Cable Colour Function 1 Yellow Left Flasher 2 Blue Fog Light's 3 White Earth 4 Green Right Flasher 5 Brown Right Side light 6 Red Brake Lights 7 Black Left Side light Quote Link to comment Share on other sites More sharing options...
Eightpot Posted May 6, 2014 Share Posted May 6, 2014 To clarify - are you just trying to wire up a trailer socket (ie just the metal 7 pin plug) or fitting a new socket complete with cable which you then need to connect to the Defender loom? The plain coloured wires without traces you found coming through a grommet, is that sticking up through the grommet and projecting behind the metal wiring cover in the corner of the seatbox, or are these wires dangling down through the grommet and close to the tow bar? If you found them behind the metal cover, you can just pull them put and bin them - probably old trailer wiring which has been cut off somewhere under the car- and in this case you need to push your new cable through the grommet, follow the wiring scheme Western posted and then match each wire with the corresponding wire in the loom - you may need a circuit diagram for your car. (if the red/blue/white/yellow etc wires you found are currently connected into the three way connector blocks, take a note of which one they came from, remove them and then refit your new cable in their place) the other bunch of wires you found is of no use to you either so ignore. hope that makes sense Quote Link to comment Share on other sites More sharing options...
Eightpot Posted May 6, 2014 Share Posted May 6, 2014 Feeling philanthropic tonight, so here goes: Yellow > green/red Blue > red/yellow white > black green > green/white brown > red/orange red > green/purple black > red/black 1 Quote Link to comment Share on other sites More sharing options...
neil3728 Posted May 7, 2014 Author Share Posted May 7, 2014 I am trying to put a whole new socket on the car as it has nothing at the moment. The 5 plain wires I found come up in the rear corner through a grommet these are all together in a neat little wrapping. The wiring on my car is a right mess as is seems to have been used by the police in the early stages of its life so has loads of extra wires kicking around. I'll have a detailed look over the weekend, but electrics is really not my strong point. Quote Link to comment Share on other sites More sharing options...
western Posted May 7, 2014 Share Posted May 7, 2014 trace the 5 plain wires to see if they are connected or just leftovers, for a new tow socket start with new 7 core cable of the correct type & new end fittings. Quote Link to comment Share on other sites More sharing options...
