fearofweapons Posted May 6, 2014 Share Posted May 6, 2014 ...from past experience, and reading on this forum, I am taking a punt my clutch fork has pulled through. (That was exciting on a BH Monday in the middle of a very busy roundabout with some blue lights trying to get past!) The clutch pedal went rock solid and I was unable to disengage the clutch to select a gear. If it is the fork I am going to replace with a heavy duty one - that certainly seems to be the consensus around replacement anyway. My question is around the clutch itself - might as well give a check and probably replace while in there. I do not do a lot of towing, and certainly nothing very heavy, I have not had any problems with the standard clutch that was in so am leaning towards replacing with a standard clutch for a 110 SW 2.5TD. Interested in thoughts and reasons though on why I might/should to go for an HD clutch instead though? (Reading the forum I could not determine if there was a pro/anti or neutral bias on this question.) Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 6, 2014 Share Posted May 6, 2014 Hmm, last time I had a solid clutch pedal problem, it was the release bearing that had melted. Quote Link to comment Share on other sites More sharing options...
Reiny Posted May 8, 2014 Share Posted May 8, 2014 In my case it was the clutch fork. Go for a HD clutch. It's worth the extra ££. I opted not to and was let down within 22 months (pressure plate warped). Second clutch was not heavy duty either and had plenty of life left in it 3 years later when the fork broke but i replaced it with a heavy duty item just the same. Quote Link to comment Share on other sites More sharing options...
