neonovice Posted May 9, 2014 Share Posted May 9, 2014 Hi, I have a key fob I need to program using Hawkeye. It's unused old stock, I believe it should have an 18 digit code with it, but I don't have that. Web searches have led me to believe I can get the 18 digit code from the 6 digit code "inside the key fob". Is this possible? If so how? Also I have had the fob to bits and although there are numbers and codes printed all over it none of them are 6 digits. Any help, as always, very much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted May 9, 2014 Share Posted May 9, 2014 If this fob is a 2 button for a Defender,you are using the wrong info,the 18 digit/6digit inside bit is for Discovery II fobs. Dont know about Hawkeye,but with Testbook or Autologic you command the security ecu into learn mode and press the unlock button 4 times for it to learn the fob,I guess Hawkeye does the same. Quote Link to comment Share on other sites More sharing options...
neonovice Posted May 9, 2014 Author Share Posted May 9, 2014 OK, it is actually for a disco1 but I am led to believe it's the same as the Defender (you get answered quicker on this forum as apposed to the disco one) The box says part number: YWX101230 This is it: Should I be able to just tell the ECU to 'learn' this fob, no codes involved? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted May 9, 2014 Share Posted May 9, 2014 Yep. Quote Link to comment Share on other sites More sharing options...
neonovice Posted May 10, 2014 Author Share Posted May 10, 2014 Piece of cake. Thanks. I would click the "like" button but apparently I've reached my quota for the day (despite the fact I have never clicked it before). 1 Quote Link to comment Share on other sites More sharing options...
