g647415 Posted May 11, 2014 Share Posted May 11, 2014 CARP! Ordered 4 new Uj for my propshafts. I order the RTC3346,' Just removed one of the shafts and took out one of the UJ. Put in the new and........DOES NOT FIT! The old (and new) does not have the RTC number on the UJ. on the old I have the following information: C5_28 33 626KN Can some one tell me which UJ does is? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2014 Share Posted May 11, 2014 they won't be marked with the LR part number. measure the diameter of the bearing cap, there are 2 sizes, you probably need the other one, is your new one to small or to big to fit the prop yoke ? Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 11, 2014 Author Share Posted May 11, 2014 they won't be marked with the LR part number. measure the diameter of the bearing cap, there are 2 sizes, you probably need the other one, is your new one to small or to big to fit the prop yoke ? Sorry. Shouold have supplied some more information. The caps are the same size, but the length is to short! Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2014 Share Posted May 11, 2014 there are only 3 LR part numbers for prop UJ's -- Rear prop UJ's item 2 in http://lrcat.com/#31/4/52612 & Front prop UJ's item 2 in http://lrcat.com/31/4/52611 the LRSeries links for info only as they have a photo. RTC3346 http://www.lrseries.com/shop/product/listing/10607/RTC3346-PROPSHAFT-UNIVERSAL-JOINT.html?search=RTC3346%20&page=1 RTC3458 no grease nipple http://www.lrseries.com/shop/product/listing/10642/RTC3458-PROPSHAFT-UJ-ASSY.html?search=rtc3458&page=1 TVC100010 with grease nipple http://www.lrseries.com/shop/product/listing/10825/TVC100010-PROPSHAFT-UNIVERSAL-JOINT.html?search=rtc3458&page=1 TVC100010 Supersedes the RTC3458 Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 11, 2014 Author Share Posted May 11, 2014 Thanks. Not sure how much that helps!? The old one HAVE grease nipple. Should this mean that its the TVC100010? Any one who can measure one for me? Length Cap to Cap. RTC3346 is about 82mm My old is 93mm Cross THICKNESS is 27mm. Could be that this is the heavy duty UJ???? EDIT: Seems its only the front prop which has these UJ. Rear had the "normal" ones. If I dont get an answer here today I will drive to Land rover tomorrow and see if they have one which we can compare. Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2014 Share Posted May 11, 2014 found this http://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_defender.htm scroll down to the 11th item first of 3 UJ info blocks. they don't give LR part numbers though, but it might help you sort what UJ you have/need this page might help as well http://www.landroverexpedition.com/articles/universal-joint-differences/ Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 11, 2014 Author Share Posted May 11, 2014 found this http://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_defender.htm scroll down to the 11th item first of 3 UJ info blocks. they don't give LR part numbers though, but it might help you sort what UJ you have/need this page might help as well http://www.landroverexpedition.com/articles/universal-joint-differences/ Thanks but my old UJ is not listed there. I will continue searching. The old is 27mm cap diam. and 93mm span cap to cap. The last in the list is 93mm span but its 30mm cap size. Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 11, 2014 Author Share Posted May 11, 2014 Found this: It seems its the Heavy option! http://www.landyzone.co.uk/lz/f7/uj-woes-251807-2.html Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2014 Share Posted May 11, 2014 this one, http://www.lrseries.com/shop/product/listing/12303/STC4807-PROPSHAFT-UNIVERSAL-JOINT.html?search=STC4807&page=1 http://www.island-4x4.co.uk/propshaft-95mm-suit-tvb100610-britpart-stc4807-p-3334.html has the info below on the page New propshaft UJ to fit TVB100610 These are the larger 95mm UJ joints to fit the wide angle propshaft TVB100610 Quote Link to comment Share on other sites More sharing options...
diggervan Posted May 11, 2014 Share Posted May 11, 2014 I have a brand new tvc 100010 and that measures 76mm cap to cap 27mm cap diameter and this for a 110 utility. Bob Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 11, 2014 Author Share Posted May 11, 2014 Yes, thanks. seems like that. Dont like that they state 95mm. Dont think the springclip would fit if 95. But my problem now is delivery time. Need to visit Land rover tomorrow anyway to get my "death clip" for the clutch fork. Will check what they want. Looking at UK price Original is about 65 pounds. Means they will probably charge me 80-90 pounds here in sweden. Lets see. Just seems odd that they have fitted a so much newer prop shaft to my 84 model.....Lets see. I will let you know tomorrow! Thanks and sorry for all the questions marks.... / Martin Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 12, 2014 Author Share Posted May 12, 2014 Land Rover in Sweden had never sold a STC4807. They could get one for me. £100 !!!!!! No thanks. But I managed to find another supplier in Sweden. They just wanted £25 so I have ordered one. I got my "death clip" from Land rover so hopefully I will update my clutch post later today! Thanks everyone for now! /Martin Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 13, 2014 Author Share Posted May 13, 2014 Quick update! Got the UJ today and I can confirm it is the STC4807. So if you read C5_53 33 62GKN on your UJ its the STC4807! THanks all! BRMartin Quote Link to comment Share on other sites More sharing options...
