HoSS Posted October 26, 2020 Author Share Posted October 26, 2020 2 minutes ago, landroversforever said: Does the Volvo have another transfer case for splitting the rear output in two? You mean for the 3rd axle? Its taken off the second axle 2 Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 11, 2021 Author Share Posted January 11, 2021 The nice thing about Covid is the extra time i get to spend in the garage... Engine fully mounted, new shocks, cab test fitting, brake line renewal started 4 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 11, 2021 Share Posted January 11, 2021 Whats the rack on the back? Spare wheel mount? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 12, 2021 Share Posted January 12, 2021 I would love to build a 304 into a camper. One day maybe. Mike Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 12, 2021 Author Share Posted January 12, 2021 8 hours ago, landroversforever said: Whats the rack on the back? Spare wheel mount? Hydraulic spare wheel lift which will double as steps when down. 2 Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 5, 2021 Author Share Posted February 5, 2021 Updates: Radiator and IC mounted. Underslung side lockers made. RHS has 2x batteries, air compressor & hydraulic pump on slide out drawers. LHS has aux fuel tank, small locker for ropes, and waste water tank. Compressed air tank mounted. Quote Link to comment Share on other sites More sharing options...
Ozzy50 Posted February 5, 2021 Share Posted February 5, 2021 @HoSS not trying to tell grandma how to suck eggs but I take it you are going to support that top hose ! loving the build 👌🏻 Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 5, 2021 Author Share Posted February 5, 2021 18 minutes ago, Ozzy50 said: @HoSS not trying to tell grandma how to suck eggs but I take it you are going to support that top hose ! loving the build 👌🏻 Yeah i was just testing length. Have to remove it to drop body on and then it will be supported to the body. Thanks. I thought someone was going to point out the lifting sling around the GB. Yes i will have to unbolt that again to get the sling off Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 5, 2021 Share Posted February 5, 2021 Please don't use that God awful convoluted radiator hose it's horrible. It splits doesn't flow very well and it looks nasty. Mike 2 1 Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 5, 2021 Author Share Posted February 5, 2021 22 minutes ago, miketomcat said: Please don't use that God awful convoluted radiator hose it's horrible. It splits doesn't flow very well and it looks nasty. Mike Ive found it ok actually for custom stuff, no evidence it does not flow, it bends better instead of kinking for custom things, and i've never had a failure. Prob depends on the quality, its not chinese.... Quote Link to comment Share on other sites More sharing options...
NRS91 Posted February 5, 2021 Share Posted February 5, 2021 1 hour ago, HoSS said: Ive found it ok actually for custom stuff, no evidence it does not flow, it bends better instead of kinking for custom things, and i've never had a failure. Prob depends on the quality, its not chinese.... Some vehicles like my 1975 Scammell Crusader even have it as standard tbh! (the radiator swings out on a pivot at the front so its needed) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 6, 2021 Share Posted February 6, 2021 20 hours ago, HoSS said: Ive found it ok actually for custom stuff, no evidence it does not flow, it bends better instead of kinking for custom things, and i've never had a failure. Prob depends on the quality, its not chinese.... I had a length of genuine Gates flexi on the 109 which failed in a new and interesting way - the wire coil wound itself out and cause the hose to collapse at certain RPM due to the water flow sucking it flat, caused random overheating. I replaced it with a length of stainless and standard universal silicone elbows/joiners on the ends, works much more lovelier now. Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 6, 2021 Author Share Posted February 6, 2021 Yeah i might do it in stainless & silicone. I found several meters of 33mm OD thrown out at work but its a little smaller that the motor 40mm, may constrict flow... Quote Link to comment Share on other sites More sharing options...
HoSS Posted August 4, 2021 Author Share Posted August 4, 2021 On 10/3/2020 at 10:06 AM, miketomcat said: I guess I'm just used to 110sw chassis which has 7 plus front bumper. I don't doubt the material is considerably thicker though. Mike Just to come back to that. I had to cut up my old chassis for disposal. Its 4mm wall with top/bottom reinforcing strips of an additional 3mm. Not a spot of rust inside after 46 years either. IIRC Defender chassis were 2.5mm Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 30, 2022 Share Posted December 30, 2022 @HoSS any more progress on this build, has been a while...... Regards Stephen Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 3, 2023 Author Share Posted January 3, 2023 Hi, Things have taken a pause due to moving and thus need to build a new workshop before much will happen again. 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted January 4, 2023 Share Posted January 4, 2023 When did you move to Brissle? Quote Link to comment Share on other sites More sharing options...
Popular Post HoSS Posted June 30, 2023 Author Popular Post Share Posted June 30, 2023 Well I've finally got the truck back to the UK, but dont yet have a garage, so work is limited to good days on the drive. And some of what you see above has once more been redesigned, as out of the blue someone fairly local to me wanted to sell a radio body, in fact one that had had some nice mod work done to it - rear door removed and the body extended. I snapped that up. So cue demounting the underslung frame (Which i was worried compromised the break-over angle anyway) and fettling a few bits to mount the std body. I'm now deep in rewiring it again as i had the fuse/relay box on the rear cab wall, and thats now a passthrough to the rear cabin. I'll post some pics over the weekend. 5 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 1, 2023 Share Posted July 1, 2023 Can’t wait ! 😊 Quote Link to comment Share on other sites More sharing options...
HoSS Posted July 24, 2023 Author Share Posted July 24, 2023 Ok some progress. Since i needed to replace the windscreens anyway, i've been pondering for some time to replace the 2-piece split screen with one piece. A few others have done it and it makes the truck look about 20 years newer. So this involved cutting out the central divider, and making corner pieces. Good old-fashioned paper template methods employed Inner corner fillets hacked out of some 3mm steel. A rather large lump of metal turned into smaller bits and several enormous brillo pads. will get these welded in by a tame welder mate. 3 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 25, 2023 Share Posted July 25, 2023 14 hours ago, HoSS said: Ok some progress. Since i needed to replace the windscreens anyway, i've been pondering for some time to replace the 2-piece split screen with one piece. A few others have done it and it makes the truck look about 20 years newer. Awww I like the split-screen look. Neat work on the corners though. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 25, 2023 Share Posted July 25, 2023 Yea those corner are outstanding 👏🏻 Quote Link to comment Share on other sites More sharing options...
HoSS Posted July 25, 2023 Author Share Posted July 25, 2023 With the aid of 2 things in my workshop that i've wanted for a long time. 4 Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 25, 2023 Share Posted July 25, 2023 Why do you need the corners? Does it allow you to fit a standard screen from something else? Quote Link to comment Share on other sites More sharing options...
HoSS Posted July 25, 2023 Author Share Posted July 25, 2023 Original windscreens are square corners, dont want to cut & glue off the shelf seals, so round corners. Have a Plexi template window temporarily, then will get a custom winscreen made up. The originals are impossible to get anyway. Quote Link to comment Share on other sites More sharing options...
