Baz2236 Posted May 28, 2014 Share Posted May 28, 2014 Hi I have a LR 90 1986 used to be a normally aspirated. Yesterday it failed the MOT on no sealling rubber on the fuel cap. It has a large vented 2 lug non locking cap does anyone know should there be a rubber washer on there if so where can I get one from. The looks to be a cork ring in the filler neck where the cap goes but it is slightly wasting away so I could do with replacing that if anyone know the number for it. Would this cork ring be enough for mr MOT man to pass it. Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2014 Share Posted May 28, 2014 should be a rubber washer seal ring on the inside, AFAIK the seal ring cannot be bought seperately, so it would be a new cap. new cap here RTC4740 or STC4072 http://www.ebay.co.uk/itm/Land-Rover-Defender-TDI-200-Locking-Fuel-Filler-Cap-RTC4740-STC4072-/320846480211 yours should look like mine inside Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted May 28, 2014 Author Share Posted May 28, 2014 Mine is a larger fuel cap metal one Quote Link to comment Share on other sites More sharing options...
g647415 Posted May 28, 2014 Share Posted May 28, 2014 Mine is also a larger fuel cap in metal. But I also dont have a seal and its very loose. I dont know if it should be like that........ First I thought that some one has remove the seal due to that the breather didnt work, but it did. I am almost affraid to lose it, but it hasent so far... Quote Link to comment Share on other sites More sharing options...
Diablo Posted May 28, 2014 Share Posted May 28, 2014 Mine's cork. and a semi knackered one at that too! Still works though. Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2014 Share Posted May 28, 2014 Mine is a larger fuel cap metal one that's the earlier cap then, http://www.paddockspares.com/nrc9572-fuel-cap-to-aa259678-vented-2-lug-non-locking.html a sheet of rubber or cork & make a gasket is the other option. Quote Link to comment Share on other sites More sharing options...
