LR 90 vented fuel cap
Hi I have a LR 90 1986 used to be a normally aspirated. Yesterday it failed the MOT on no sealling rubber on the fuel cap. It has a large vented 2 lug non locking cap does anyone know should there be a rubber washer on there if so where can I get one from. The looks to be a cork ring in the filler neck where the cap goes but it is slightly wasting away so I could do with replacing that if anyone know the number for it. Would this cork ring be enough for mr MOT man to pass it.
Mine is also a larger fuel cap in metal. But I also dont have a seal and its very loose. I dont know if it should be like that........
First I thought that some one has remove the seal due to that the breather didnt work, but it did.
I am almost affraid to lose it, but it hasent so far...
