Troll Hunter Posted June 3, 2014 Share Posted June 3, 2014 Hi, All, My vehicle originally had a Mid-east 3.5L V8 but now has a 300Tdi. Please can somebody tell me the duty of each of the relays mounted inside the fuse box below the fuses. Mine has 8 relays. From the left, looking at the box, the first two are green, and the remaining 6 are yellow. When the engine transplant was done, by others, some duties may have changed, but I have no idea of the duty of any of them. Many thanks for any info. Mike Quote Link to comment Share on other sites More sharing options...
henk Posted June 3, 2014 Share Posted June 3, 2014 Have a look here: http://albrit.de/UNI.cfm?PAGE=763899&SPRACHE=EN or on other pages there Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2014 Share Posted June 3, 2014 extracted from my rave manuals electrical section, for V8i defender 6 yellow relay's, can't find any info on the 2 green relays the C**** idents relate to the matching wiring diagram connection points. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted June 6, 2014 Author Share Posted June 6, 2014 Henk, Western, Many thanks, both, for your input. Between the info you gave and some trial and error I've sorted the unrecorded changes that were made when the engine transplant was made. Mike Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2014 Share Posted June 6, 2014 glad you managed to figure out the changes. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted June 9, 2014 Author Share Posted June 9, 2014 Hi, All, I seem to still have an intermittent short causing me to randomly have a flat battery, which is what the OP was about. In following up with a multi-tester, with the battery removed, I get the following results: Between positive and negative battery leads Zero resistance I assume this could be because of the clock and radio memory circuits, but I'm not sure. Between the following locations and earth: At the fuses in the fuse box, at all except the four headlamp fuses Zero resistance The four headlamp fuses Open circuit At the main starter connection stud, on the solenoid, all leads connected Zero resistance At the main starter solenoid stud, with all the leads disconnected Open circuit On the leads that I've disconnected from the starter stud: Heavy Brown lead Open circuit 2 thinner Brown leads Zero resistance Red/black lead Open circuit Heavy Red lead (main connection between battery and starter) Open circuit Red/white lead connected to other terminal on solenoid (closer to engine block) Open circuit (Power to operate solenoid) With the battery positive lead connected and using a test lamp between the negative lead, which is disconnected, and the battery negative post the test lamp illuminates brightly for about 1 second and then fades away completely. If I break the circuit for a couple of seconds and then re-connect the test lamp it repeats the brightness and fading away. I am totally baffled. Is this the result of a capacitor charging up and then being discharged through the test lamp? (I’m showing off my in-depth knowledge of electrickery now. I know how to spell capacitor!) Any help will be very much appreciated, and many thanks in advance. Mike Quote Link to comment Share on other sites More sharing options...
