88inchthing Posted June 4, 2014 Share Posted June 4, 2014 Hi I have been asked by a good friend to ask on here if fuel leaking into the oil on his 2002 Disco TD5 is a known problem? He has got the idea from somewhere that it may be due to a cracked head? Should probably point out at this stage that we haven't even pulled the rocker cover of yet, he is just rather anxious to known if it's a common fault. Thanks in advance Bill Quote Link to comment Share on other sites More sharing options...
Phantom Posted June 4, 2014 Share Posted June 4, 2014 Last one I fixed was a failed head Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 4, 2014 Share Posted June 4, 2014 Failed head, failed injector or possibly the seals between the two leaking. Hope for the last one, as the others are effin expensive! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 5, 2014 Share Posted June 5, 2014 I'd go with injector seals first, as they're cheap, and if it proves not to be them, it hasn't cost much to find out it's going to be expensive. A friend had a 200 head rebuilt at a cost of £700 to cure overheating, only to discover it only needed a £100 radiator.... Quote Link to comment Share on other sites More sharing options...
IanS Posted June 5, 2014 Share Posted June 5, 2014 It's also a good idea not to drive it as there have been instances of the engine running away if the sump gets too full. Nasty...... Quote Link to comment Share on other sites More sharing options...
88inchthing Posted June 5, 2014 Author Share Posted June 5, 2014 Thanks for the replies.Looks like injector seals should be the first of call. Quote Link to comment Share on other sites More sharing options...
