Lancealot Posted June 12, 2014 Share Posted June 12, 2014 Hi all big headache I have prob with fuel not reaching outlet of injector pump Parked up next morning no start, I've changed lift pump, removed fuel cut solenoid, pumped lift. Pump and get diesel come out of solenoid port, checked solenoid works and it dose, replaced solenoid less pin, hand pumped lift pump no fuel through out let of injector pump, refitted lift pump cranked engine still no fuel Help plz Quote Link to comment Share on other sites More sharing options...
Meatslicer Posted June 12, 2014 Share Posted June 12, 2014 Blocked jets or leaking fuel pump? Any smell of diesel in the engine bay? (More than normal!) Next thing would be hand pump a large amount of fuel to check for air/vapour locks in the fuel lines. Even further back, is the breather clear? try turning over with fuel cap off. if it flows the breather is blocked with dirt or grease. Eric Quote Link to comment Share on other sites More sharing options...
Lancealot Posted June 12, 2014 Author Share Posted June 12, 2014 No smell of diesel no leaks I can get fuel to hand pump out of fuel stop solenoid port no pipes fitted to outlet of injector pump its 300tdi no spider or anything fitted engine was taken from a M reg disco and fitted in to defender approx 4 yrs ago the lift pump was faulty hence the replacement fitted Quote Link to comment Share on other sites More sharing options...
Lancealot Posted June 12, 2014 Author Share Posted June 12, 2014 Ok slight up date I have removed feed into inject pump turned engine over and not a lot of fuel coming through i can get more fuel through hand pumping lift pump Quote Link to comment Share on other sites More sharing options...
m&mv80 Posted June 12, 2014 Share Posted June 12, 2014 Cam belt? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted June 12, 2014 Share Posted June 12, 2014 Lift-pump arm-that-runs-on-the-camshaft-lobe sheared-off the lift-pump? You should get lots of Diesel when you crank the engine with the lift-pump-to-injection-pump pipe union 'cracked' open slightly. [Must admit, I consider clockwork engine-driven lift pumps to be the spawn of Satan: having to crank the engine to prime the fuel-system is IMHO so totally wrong] Quote Link to comment Share on other sites More sharing options...
Lancealot Posted June 12, 2014 Author Share Posted June 12, 2014 Fitted new lift pump today it's going in to landi garage I'll let you know what happens Quote Link to comment Share on other sites More sharing options...
diggervan Posted June 13, 2014 Share Posted June 13, 2014 If you are getting more fuel out of lift pump by hand priming than you do by cranking engine on the key then it's either arm on lift pump bent or to short or cam lobe badly worn Bob Quote Link to comment Share on other sites More sharing options...
