challenge_king Posted June 26, 2014 Share Posted June 26, 2014 Hey guys, noticed today that I have quite a bit of smokey fumes coming from the breather on the top of my 200tdi engine, that sits on the left of the rocker cover. Surely this isn't normal? Thought it could maybe be a cracked gasket causing it to blow like this? It builds quite a bit of pressure when you put your hand over it. Thanks in advance! Ethan Quote Link to comment Share on other sites More sharing options...
jbs Posted June 26, 2014 Share Posted June 26, 2014 Check your breathers on the engine-rocker cover etc. John Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 27, 2014 Share Posted June 27, 2014 200tdi's generally breath quite heavily. If you're not getting any other symptoms I wouldn't worry too much. A blown head gasket will make itself known quite soon if it has gone. Quote Link to comment Share on other sites More sharing options...
challenge_king Posted June 27, 2014 Author Share Posted June 27, 2014 Yes I have, and this is where the air is coming from, the large breather on the left of the rocker cover. Quote Link to comment Share on other sites More sharing options...
diggervan Posted June 27, 2014 Share Posted June 27, 2014 It's possible piston rings gummed up / valve guide seals/ head gasket more than likely piston rings if it's a high mileler try changing oil good quality run for 200 miles or so and change again it will take a bit of time but changing oil often will help Quote Link to comment Share on other sites More sharing options...
western Posted June 27, 2014 Share Posted June 27, 2014 shouldn't be any gases coming from the breather to outside, check the hoses are intact & the breather body is not cracked my 200tdi is 18 years old with stellar miles & doesn't let gases escape from the breather into the engine bay. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 27, 2014 Share Posted June 27, 2014 my 200tdi is 18 years old with interstellar miles & doesn't let gases escape from the breather into the engine bay. FTFY :-) Quote Link to comment Share on other sites More sharing options...
western Posted June 27, 2014 Share Posted June 27, 2014 FTFY :-) took me a while to notice what you had done Quote Link to comment Share on other sites More sharing options...
WHO4 MUD Posted June 28, 2014 Share Posted June 28, 2014 have you checked the dip stick when running? i had broken piston rings and it was chuffing out there as well. Quote Link to comment Share on other sites More sharing options...
marktdi Posted June 28, 2014 Share Posted June 28, 2014 When was the breather last changed Quote Link to comment Share on other sites More sharing options...
