FridgeFreezer Posted July 19, 2014 Share Posted July 19, 2014 While tracing mystery wires on our 127, I've tracked down a pair of wires going to what appears to be a factory-fit split-charge setup. From the battery box there is a brown/white wire heading off to a Lucas 33RA relay (standard 60A relay) mounted on the bulkhead. Wires going in are: Large brown/white from battery box Large brown from battery box Small black Small green The black & green come from a 3-terminal connector on the passenger side by the heater which also contains a small brown wire. It's a 1988 127 and this appears to be part of the factory-fit loom. Does anyone have a diagram to confirm this, or anything from the optional extras part of a manual that describes it? Quote Link to comment Share on other sites More sharing options...
jbs Posted July 19, 2014 Share Posted July 19, 2014 Fridge, Ralph will more than likely be the person to speak to about this John Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 19, 2014 Share Posted July 19, 2014 I believe Ralph (Western) uses this system on his 110 so he'll be the man to ask I would think. Quote Link to comment Share on other sites More sharing options...
western Posted July 19, 2014 Share Posted July 19, 2014 Correct. that's the split charge relay unit. parts book page http://lrcat.com/#31/4/52838 IIRC there's a 3 way connector adjacent to the inner side of the heater box, it should have 3 wires green, black/slate tracer,brown.the plug opposite the number 1 in the parts page connects to it. I will check my 110 & confirm with a photo/list which wires fit where on the split charge relay. Quote Link to comment Share on other sites More sharing options...
western Posted July 19, 2014 Share Posted July 19, 2014 First some terminal & wire info Large terminal marked 30 = thick plain Brown wire to vehicles Primary [start] battery Positive terminal Large terminal marked G = thick Brown/White trace wire to 2nd battery positive terminal small terminal marked 85 = Plain Green wire [fully insulated] spade terminal small terminal marked 86 = Black/Slate trace wire [fully Insulated] spade terminal last 2 go with in the split charge sub loom to the 3 pin side by side rubber covered socket adjacent to heater unit inner face. [see photo with my finger behind the connection.] Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 19, 2014 Author Share Posted July 19, 2014 Cheers Ralph, you're a star! I haven't found the "switch, volt sensitive" yet, I assume the skinny brown wire from the 3-pin connector by the heater goes to it, is there a wiring diagram for this kit? I'm trying to make sure I know what all the wires in the battery box do before I start connecting or disconnecting things, so far we have factory loom, factory optional split-charge and then military ambulance additions... I've already removed the PO's three-battery-split-charge setup for now just to simplify things! Quote Link to comment Share on other sites More sharing options...
western Posted July 19, 2014 Share Posted July 19, 2014 "switch, volt sensitive" aka VSR lives in dash right forward corner behind the instrument pack & the 3 rocker switch by the door, right of steering column. it's a yellow case unit. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 20, 2014 Author Share Posted July 20, 2014 You are the oracle of all things Ralph! Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2014 Share Posted July 20, 2014 Glad the info helped, your welcome Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 26, 2015 Author Share Posted July 26, 2015 Follow up as I've just removed the dash - Ralph is the guru, yellow VSR exactly where he said it would be! 1 Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 26, 2015 Share Posted July 26, 2015 Remind me Fridge, is it a Locomotors body or Marshal? Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2015 Share Posted July 26, 2015 glad the info helped looks to be a Marshall body to me, the Locomotors have a boxier roof line & a double angle to the panel above the front screen. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 26, 2015 Share Posted July 26, 2015 I owned one Ralph, remember? Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2015 Share Posted July 26, 2015 Yeah, my friend Bob bought from you. wonder where it is now Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 27, 2015 Author Share Posted July 27, 2015 It's Marshal: 1 Quote Link to comment Share on other sites More sharing options...
physicstype Posted January 10, 2018 Share Posted January 10, 2018 Hi, this seems to be the only post on the net where some mentions the brown/white trace leads with the split charge system. I have a AMR3135 split charge harness and am trying to figure out how to hook it up. The only information that I found that was close to what I have, is here in western's post. Has anyone seen this late factory version of the split charge system installed? I am struggling to figure out how to hook it up. a) I am unsure whether the black lead is there to connect the two battery terminals b) on one end of the harness, the eyed lead ends are of equal length, so it seems they hook up to some sort of terminal connector instead of a battery; they just aren't long enough. However, the parts cat doesn't list any such part. Do you have any idea how this is supposed to be hooked up: I'd be incredibly glad if someone would have any type of information on this... Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2018 Share Posted January 10, 2018 Only further info I can find for loom AMR3135 is it fits vehicles from chassis number MA939976 to WA159961 which would be 300Tdi & onwards maybe its meant for Td5 vehicles which have a different alternator/battery sensing system, IIRC 300tdi & Td5 have underbonnet [engine bay] fuse boxes with big maxi fuses in, maybe they ring ends go to terminals in that fusebox, no idea why it has plain black wires, usually plain black on 90/110/Defenders is earth/ground Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 11, 2018 Share Posted January 11, 2018 Having a look at what you have in the loom, you'll need SRB600 relay... http://www.bowerspartsonline.co.uk/brands/lucas/genuine-lucas-srb600-33419-12v-33ra-60a-4-pin-split-charge-relay this will take care of your two small ring terminal br & br/wh and the two spade connectors. The brown with (?) is that a threaded rod?, if so that will replace the battery clamp bolt on the primary battery, large ring terminal br/wh to 2nd battery. Black wire...Looks like an earth to me VSR...can't seem to find a part number but maybe Ralph can? Gr/bk wire...no idea. Looking at a td5 loom the Gr/bk does the low fuel warning light on the cluster. It'll be ignition switched..is this Gr/bk on the VSR multiplug? Not many bullet connectors on a td5 loom though. Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2018 Share Posted January 11, 2018 VSR = PRC4427 yellow case. http://www.brit-car.co.uk/product.php/89705/4590/voltage_sensitive_switch____defender___discovery___range_rover_classic  & just to confirm Scotts90 find that is the same unit as I have fitted. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 11, 2018 Share Posted January 11, 2018 Knew you'd have that info Almost covered the keyboard in tea when I saw the price of it though!! £200 for a VSR! Jeeso... Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 11, 2018 Share Posted January 11, 2018 11 minutes ago, Scotts90 said: Knew you'd have that info Almost covered the keyboard in tea when I saw the price of it though!! £200 for a VSR! Jeeso... Yeah same reaction, I'm sure I've got a couple of those relays I've reclaimed from one place or another knocking around too! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 11, 2018 Share Posted January 11, 2018 RRCs have these IIRC, to switch out the heated screen. Scrapyard is your friend Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2018 Share Posted January 11, 2018 any 90 or 110 with heated rear screen has it too, have a look on eBay for one Quote Link to comment Share on other sites More sharing options...
