Scandi Posted August 4, 2014 Share Posted August 4, 2014 I am very happy to have found a well equipped, nice, low mileage 2004 Td5 Defender in which I have just replaced the standard intercooler with the large Allisport model and a Boost/EGT combo gauge. The vehicle is already equipped with a PSI Motorsport "IP-Powerbox". The issue now is that I register temperatures in excess of 900 Degrees C when pushing hard. Boost reading noted is 0.9 bar when wastegate opens. There is still a lot of smoke but only when pushing hard, although less than with the standard intercooler. My main concern is the temperature and I wonder if anyone out there has experience with this PSI Gadget. There are jumpers inside the box and I assume there are different fuelling levels possible by changing these. I have sent a query to PSI in Luxembourg, but would like to hear from anyone out there having experience with this and perhaps had the chance to play around with the settings. I believe by reducing the fuelling the temperatures would drop to acceptable levels not to damage turbo. The smoke should then also reduce. Lars Quote Link to comment Share on other sites More sharing options...
