robbie1717 Posted August 10, 2014 Share Posted August 10, 2014 Just about to start revamping my braking system, got calipers rebuilt (sandblasted, S/S Pistons, new seals fitted & reassembled) and was thinking of painting them. Would it be alright to give them a clean with Thinners to remove any leftover Grease, Brake Fluid etc prior to applying the paint? I've heard/read a few different ideas on this, some people are saying the thinners will swell the seals & others seem to think it will be fine ......... Anyone have any advice on this? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2014 Share Posted August 10, 2014 I'd be using correct brake parts cleaning fluid rather than a gash tin of thinners, but if thats all you can get just keep the thinners off the seals & rubber dust covers. Quote Link to comment Share on other sites More sharing options...
robbie1717 Posted August 10, 2014 Author Share Posted August 10, 2014 more of wiping with a rag soaked in the stuff rather than rinsing them in a container filled with it then? I've also got Isopropyl Alcohol? Would that be any different or an improvement? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 10, 2014 Share Posted August 10, 2014 IPA is certainly less aggressive than thinners when it comes to attacking stuff. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted August 10, 2014 Share Posted August 10, 2014 I painted mine and used spray brake cleaner and a clean rag to clean the calipers first before painting (used Halfords blue caliper paint has worn really really well cant fault it) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 10, 2014 Share Posted August 10, 2014 IPA is certainly less aggressive than thinners when it comes to attacking stuff. Greene King IPA ? I think I'd use Abbot Ale myself Mo 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 10, 2014 Share Posted August 10, 2014 Greene King IPA ? I think I'd use Abbot Ale myself Mo A few pints of that will certainly break the seal though....... Quote Link to comment Share on other sites More sharing options...
robbie1717 Posted August 11, 2014 Author Share Posted August 11, 2014 Used IPA in the end, on a rag and gave them a good wipe over rather than rinsing them in a container of it. Sighnbox i'm also using the Yellow Halfords Caliper paint (small 250ml cans) - what sort of drying times did you have with yours? Quote Link to comment Share on other sites More sharing options...
JeffR Posted August 11, 2014 Share Posted August 11, 2014 If you read the back of a tin of brake/carb cleaner, you will fid the major constituent of it is isopropyl alcohol. Find your local chemical suppliers to buy it from - tends to be a hell of a lot cheaper. Just be careful what type of plates spray thingy you use it in as it can melt some types of plastic. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted August 14, 2014 Share Posted August 14, 2014 Robbie LONG LONG LONG drying times in fact I thought there was some thing wrong about 2 days to dry properly each coat Quote Link to comment Share on other sites More sharing options...
