western Posted August 18, 2014 Share Posted August 18, 2014 I have a defender 200tdi and the rear fog lights are not working. I have checked connections for rear light bulbs and changed both units as both the red terminal pins had corroded. However with the new units they still don't work. Plus no power supply coming through to them? I have checked the fuses. The 6th fuse is fine. The horn works when 1st fuse (20A) for horn and fog is removed? Not sure how? I have also checked the terminals inside the fog light switch and cleaned them. Still no life? This is really racking my brain and can't seem to think of any ideas? Can someone please give any advice? The MOT has run out and this needs to be fixed before it goes in. Thanks! I got sent the above today, think it should have gone in the forum, can any one advise kidoletatu Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 18, 2014 Share Posted August 18, 2014 Are the headlights working? My foglight stopped working when the headlight switch melted. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted August 18, 2014 Share Posted August 18, 2014 Is your loom in the chassis? Possible chaffed wire? Have you checked continuity from the light to the switch/fuse? Quote Link to comment Share on other sites More sharing options...
pete3000 Posted August 19, 2014 Share Posted August 19, 2014 Don't discount the switch itself, my 20 odd year old switch had clagged up contacts and wouldn't work for an mot until i rattled the swtich back and forwards to wear the grime off. The switch is a two pin jobby so you can remove the intrument shroud and bridge the loom with a wire to try the foglights. Wire trace should be red/yellow after switch think it's blue or blue/red to feed the switch with 12v once the headlights are on via the blue wiring Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 19, 2014 Share Posted August 19, 2014 Some Defenders have an extra inhibitor relay in the [rear] fog-light circuit that's activated by a feed from the parking-light circuit. The idea of this is to stop you driving with the fog-lights on but only your parking-lights (or dim-dip headlights) on. Given how infrequently rear fog-lights are actually used it's not unusual for the contacts in the switches/relay/appropriate fuse to get a bit 'green' with surface corrosion. Quote Link to comment Share on other sites More sharing options...
TheKeymeister Posted August 19, 2014 Share Posted August 19, 2014 I had a flickering brake light that decided to come on randomly, including when parked up...turned out to be a wiring bodge done when someone changed the rear crossmember, the brake light wire was shorting to the permanent live feed. I think the reverse light circuit had gone open circuit as well. There were 15 or so red crimps all wrapped up in electrical tape that had gone green and crusty, so it might be worth looking for something similar... Quote Link to comment Share on other sites More sharing options...
kidoletatu Posted August 25, 2014 Share Posted August 25, 2014 Are the headlights working? My foglight stopped working when the headlight switch melted. Yeah the headlights are working. I have managed to fix them. Kept fiddling with the connections of the light unit and presto!! Mind of its own! Cheers Quote Link to comment Share on other sites More sharing options...
kidoletatu Posted August 25, 2014 Share Posted August 25, 2014 Thanks guys. I have managed to get it working by fiddling more with the connection to the unit. Weird but it seemed to work..for now. I still think the electrics are not great in this car. When I put high beams on the stereo goes off? Is that standard? Quote Link to comment Share on other sites More sharing options...
western Posted August 25, 2014 Author Share Posted August 25, 2014 sounds like the end fittings on the wires need cleaning or replacing, they do corrode & that upsets the elect current flow, no headlights shouldn't have any affect on the stereo. Quote Link to comment Share on other sites More sharing options...
