Les Brock Posted October 28, 2006 Share Posted October 28, 2006 Current carrying capacity of tri-rated cables http://www.clevelandcable.com/page124.htm on mine twin alternators 80 amp and 100 anp both have 25mm' back to the batteries Quote Link to comment Share on other sites More sharing options...
jules Posted October 28, 2006 Share Posted October 28, 2006 I have done a few 4.2 convertion and I have spliced to much later 4.2 engine hernese into the much older A and B reg 90's and 110's and its all the same colours just diffrant size cables and plugs. 2.5 petrol taken 65amp out and 4.2 100amp fitted. If I can do it so can your Cat it's that simple using off the shelf parts from later RR's. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 28, 2006 Author Share Posted October 28, 2006 DEAR GOD ARRRRGGGHHHHHHHHH Just finished for the day. Now have nice 90 amp alternator on now a......nd FINALLY working, ... NOT a simple nuts and bolts jobbie as I thought, .........but neat and powerfull enough for what I want none the less. Will do a write up if people are interested, but off now for a chinky with my mate.... (who solved the burning smell we had from it when it was started up).............. yer learn something every day.....well I do from him thats for sure Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 29, 2006 Share Posted October 29, 2006 Own up Nige, what wassit? Quote Link to comment Share on other sites More sharing options...
bathtub Posted October 29, 2006 Share Posted October 29, 2006 Pete - how much is the Premier Power one? 120A for £15 at the scrappy or an extra 10A for how much extra wonga? ERRRRRRRRRRRRRRR DE-NILE is a river in africa like you think a LR 120 amp alternator gives out that much Maybe at 16k revs down hill @ Xmas with a following wind Thats what i had on mine before but winching at night with all the lights on etc & at low revs the batterys & alternator failed miserably With the new 1 at ticker over the volt-meter just drops for a second then sits back at 13/14 volts But hey stick with the £10 second hand 1 if your happy & as youve got a hydraulic winch then your be fine anyway AS to 24v still not convinced think i will go hydraulic if it gets to that extent Slightly off subject why cant i run 2x 12v batterys to give me 24v to my winches instead of running 24v alternator etc ?????? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2006 Share Posted October 30, 2006 Pete: Who said anything about a LR alternator? Current one is off a Merc Sprinter but is identical to a Mondeo one - 45A at idle / 90A full chat. I'd never trust a LR one and anyway all the chequebook boys snap those up for big bucks because they are bolt-on Dad's running a Ford Cosworth alt on his, that actually was a straight bolt-on. 24v - you'll need two 12v batteries AND a 24v alternator if you go 24v, only having one or the other will probably result in a small fire, followed by a large fire Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 30, 2006 Share Posted October 30, 2006 Nige I get cable of the sizes talked about here in Aldershot, cheap and good, welding suppliers down by the football ground. Close to Muddy Trax. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2006 Share Posted October 30, 2006 What he said - it's not worth mucking round with genuine parts bits of wire like that as they're only ever going to be the thinnest/cheapest they can get away with. A decent bit of fat cable will improve matters greatly - just like you've found with your engine earths Welding cable is much more flexi than the usual battery cable or the stuff VWP sell and the insulation tends to be thicker as it's designed for more abuse. Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 30, 2006 Share Posted October 30, 2006 Pete, going 24V isn't hard; just mount the alternator (hardest part) and then wire in the charge circuit, warning light and winch wiring. Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 30, 2006 Share Posted October 30, 2006 Theres another way to go 24V with a std 12v altenator - Have the 2 bats in parallel for charging and series for winching. It would require 3 relays (high current). Then all of the other electrics can stay as they are. Quote Link to comment Share on other sites More sharing options...
bathtub Posted October 30, 2006 Share Posted October 30, 2006 Theres another way to go 24V with a std 12v altenator - Have the 2 bats in parallel for charging and series for winching. It would require 3 relays (high current).Then all of the other electrics can stay as they are. THATS WHAT I WAS ASKING Fridge ?????? Any comments on this ?? Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 30, 2006 Share Posted October 30, 2006 THATS WHAT I WAS ASKING Fridge ?????? Is that a statement or a question? To qualify my comment - I have never tried it or heard of anyone doing it. But I can see no problem. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2006 Share Posted October 30, 2006 It works in theory... practically at the very least you need to make sure the relays switch in turn otherwise you could end up with some nasty momentary shorts. Also while winching presumably if you have a 12V alt then you're only charging one battery as the other one is floating "on top" of that, so one battery is getting 100A of charge, the other is being wound flat by the winch and getting nothing back. This does not make for happy batteries, when you switch them back they will then try to equalise the voltage and you'll effectively be jump-starting one battery through a relay. Given the winch setup you're running and the potential for drawing 500A+ for a significant time you're gonna need some frickin' big relays. I can see the whole cycle getting a bit tedious: Drive along Get stuck Switch to "winch mode" Winch till the "top" battery is flat Switch back to "drive mode" "Drive" battery then dumps a sh*tload of charge into the flat battery Sit there waiting for both batteries to recover/recharge Switch back to "winch mode" Winch a bit more Etc. There is the issue that if you wind the setup down so one (top) battery is dead flat and the other is just about clinging on 'cos it has the alternator keeping it charged, then you switch back to "drive mode", suckng the last life out of the drive battery, both will end up proper flat and you're then sat dead in a puddle with two flat batteries I can't imagine this is going to be much good for either battery, and I'm sure there was some story out there about someone running a similar setup who ended up with a battery under the seat exploding We need Bull Bar Cowboy to explain it with big words really Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 30, 2006 Share Posted October 30, 2006 It works in theory[/iI can see the whole cycle getting a bit tedious: Drive along Get stuck Switch to "winch mode" Winch till the "top" battery is flat Switch back to "drive mode" "Drive" battery then dumps a sh*tload of charge into the flat battery Sit there waiting for both batteries to recover/recharge Switch back to "winch mode" Winch a bit more Etc. sounds almost as slow as winching with a hydraulic winch, i did say 'almost' Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2006 Share Posted October 30, 2006 Slow like this? Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 30, 2006 Share Posted October 30, 2006 need one on yours jon, cos it still doesn't drive Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2006 Share Posted October 30, 2006 It's getting closer though - rolled it out of the lab yesterday, looks a bit small next to Petal though and we couldn't make it jump pushing it along by hand Quote Link to comment Share on other sites More sharing options...
