mcc1979ian Posted September 12, 2014 Share Posted September 12, 2014 Ok so after a long delay on the rebuild I'm almost ready to fit my 4.6 into my 90 but my question tonight is which chassis mounts do I need and are the p38 mounts ok from engine to rubber or do I require a specific mount for this too? Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted September 12, 2014 Share Posted September 12, 2014 The P38 mounts are very different from standard defender ones, if yours are the type with two bolts on each mount. They would make the engine sit much higher unless you dropped them down on the chassis side, but they are also over complicated and far harder to change. For simplicity and ease, I would go with standard V8 defender mounts chassis and engine, that way they're a known quantity in that car and you're not inadvertently guinea pigging your setup. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted September 15, 2014 Author Share Posted September 15, 2014 Ok thanks for that Quote Link to comment Share on other sites More sharing options...
