Sign in to follow this
kudlinski
Td5 electrical gremlins
My 110 currently is playing silly devils with its lights. Mi currently have no rear indicator, brake light, or side light on the ns. I have swapped the fittings over from the OS and the fittings are ok, fuses are fine.
Anyone cleverer than me with ideas from here?
Thanks
Paul
Share this post
Link to post
Nearside lights are fed from the offside, take off the cover plate on the OS and check the connections.
Share this post
Link to post
I had a similar problem on a Mini once. The previous owner had put a number plate light fitting in the wrong way around, allowing one of the contacts to short off the body.
So maybe you have a short like that.
Share this post
Link to post
