africanpete Posted October 13, 2014 Share Posted October 13, 2014 Hi All Can anyone tell me where the two earth cables that come from the negative battery terminal connect to? I stripped my engine bay around 3 years ago as part of a full rebuild and have only just started putting things back together (it's been a very busy few years!) I took photos of everything as I stripped it but unfortunately lost these... Any help appreciated, pics below of the cables in question Thanks Peter Quote Link to comment Share on other sites More sharing options...
africanpete Posted October 13, 2014 Author Share Posted October 13, 2014 And another pic Quote Link to comment Share on other sites More sharing options...
bear Posted October 14, 2014 Share Posted October 14, 2014 Hi Peter. Do a search for RAVE the LR work shop manual and it should be in the elecs section. Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted October 14, 2014 Share Posted October 14, 2014 This LR electrical library manual might also help - it's got photos of the components / connecting points - it covers 99MY to 03MY. If it's the same as bear is recommending I apologise - I'm not too familiar with all of the manuals http://macassemble.com/lrm/discovery_ii/Discovery%20II%20Electrical%20Library.pdf Quote Link to comment Share on other sites More sharing options...
africanpete Posted October 15, 2014 Author Share Posted October 15, 2014 Thank you gents, I think I got there in the end, fingers crossed I'm sure all the info is in RAVE and the library above but I'm useless with electrical diagrams Just to close it out - I think the thicker cable goes from battery negative to a bolt on the alternator mounting bracket, thinner cable goes to a lug on the inner wing sort of between the fuse box and brake fluid reservoir Thanks again Quote Link to comment Share on other sites More sharing options...
