Fibre glass roof for WOLF 90
jameshub
 Share
ebay seems empty,depends how deep your pockets are try either withams, pa blanchards, drop zone surplus. or milweb.net ads. You will get one it just depends on how much you have. A cheaper route if you have the roll cage and soft top would be to fit one or two rad haz kit's off ebay.
They are good value for money, in tems of keeping down the condensation and adding a layer or 2 of insulation (trapping air between layers. Make your own fume curtain with a tough poncho over the front roll hoop. This will mean the heater only has to heat the front 2 seats.
The rad haz kits are closed cell foam covered with mica/antistatic bag material which works well as a moisture/heat barrier I have found.
http://www.ebay.co.uk/itm/Land-Rover-Military-Defender-110-Wolf-XD-TUM-Radiation-Hazard-Insulation-Kit-/181562504241?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a45f7f431
worth asking the surplus seller linked, he might be able to help with hardtop or know where to find one.
thanks for the advice i will try him
thanks
 Share
