missingsid Posted October 26, 2014 Share Posted October 26, 2014 So currently I have a Rangey Classic pre engaged starter motor on my 3.5. This has the solenoid on the side of the starter rather than underneath on the car starters. I know that Bendix type starters damage the starter ring gear and that they can jam but twice now I have been stopped offroad by the pre engagement solenoid piston becomming blocked by liquid sand or mud. I can't help but think a Bendix starter would be less likely to jam? Are they available for RV8 engines and does anyone have experience of them? Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 26, 2014 Author Share Posted October 26, 2014 I have seen a Bosch solenoid STC4462 which has a rubber boot over the exposed piston but it is £130! Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 27, 2014 Author Share Posted October 27, 2014 So looking arround I have found out the following. P38 is a Bosch type which has a rubber sleve on the solenoid as above. Lucas for Rover P5 also has a rubber boot for solenoid. So do I buy the P38 starter. S/h with 90 day garuntee of ebay or P5 solenoid also of ebay, both are same price? will the P38 fit my SD1 block? Marc Quote Link to comment Share on other sites More sharing options...
Team Idris Posted October 27, 2014 Share Posted October 27, 2014 I'd go buy yourself a new bosch style and silicon the holes up. They aren't that expensive from Crads. I run one and carry a spare (auto). The big wound lucas is better when the engine is hot. The Bosch is normally faster on most vehicles. I've never seen a bendix style for the RV8. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted October 27, 2014 Share Posted October 27, 2014 I've too been trough many a starter on my rv8s but ever since I bought the Denso geared starter from paddocks I haven't had a single,problem! And it draws much less current to start the,engine so the spark remains powerful and, starting is done much quicker and nicer. And at that silly low price I will never choose otherwise. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted October 27, 2014 Share Posted October 27, 2014 and forgot to add that I does have that rubber boot as well Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 27, 2014 Author Share Posted October 27, 2014 Thanks guys, So two choices to look at, the first I know but the second I need to follow up. Marc Quote Link to comment Share on other sites More sharing options...
task Posted October 27, 2014 Share Posted October 27, 2014 You could also consider one of the "hi-torque" type geared starter motors, I've just fitted one to my MGB GT V8 project, mostly due to space constraints, but it seems like a nice robust bit of kit. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 27, 2014 Share Posted October 27, 2014 I use on my 5.2 jed full race rover v8 with 10.7:1 compression a genuine bosch unit and a decent big f battery... Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 28, 2014 Author Share Posted October 28, 2014 Called Paddocks and they had no idea about PMGR starters, so I looked on line at WOSP racing starters and they are based on both Denso and Bosch starters as they are the same design and presumably quality? Choice of £78 Denso new from Paddocks or £34s/h Bosch with 3 month garuntee I chose the Bosch as it is known to have the sealed solenoid and I'm broke anyway. So I fitted the new on today, much easier to fit as the smaller motor allows the use of a socket, turned key and wow it's so fast! I will keep the old one as a spare but don't want to go back to it really. Marc. Quote Link to comment Share on other sites More sharing options...
