robertspark Posted November 25, 2014 Share Posted November 25, 2014 For the most accurate way to do this you're looking to put your alignment marks where the screwdriver moves up and down quite a bit in relation to very little crankshaft rotation (somewhere like 45 to 75 degree past / before tdc for your initial go) then mark the midpoint. You can then bring your second go marks a little closer in with a second mark on the screwdriver Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 25, 2014 Share Posted November 25, 2014 If you use a solid stop, a hollowed out sparkplug with a stub welded into it, it is very accurate indeed, and the flopsiness of the screwdriver doesn't come into account anywhere. Quote Link to comment Share on other sites More sharing options...
robertspark Posted November 25, 2014 Share Posted November 25, 2014 If you use a solid stop, a hollowed out sparkplug with a stub welded into it, it is very accurate indeed, and the flopsiness of the screwdriver doesn't come into account anywhere. Thanks I'll remember that one defiantly ... something like a nut welded in the end with a bolt welded to it as a stop (set to the right depth) Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 25, 2014 Share Posted November 25, 2014 ....and I got curious, yes they are made commercially, e.g: http://www.summitracing.com/int/parts/sum-900189/overview/ Lots of images of them, including DIY versions: https://www.google.co.uk/search?q=%22piston+stop%22&espv=2&biw=1680&bih=888&tbm=isch&imgil=BjutEvp--Yip3M%253A%253BgVM68FxPmXB_nM%253Bhttp%25253A%25252F%25252Fwww.motoiq.com%25252FMagazineArticles%25252FID%25252F2284%25252FPageID%25252F4012%25252FHow-To-Degree-Cams.aspx&source=iu&pf=m&fir=BjutEvp--Yip3M%253A%252CgVM68FxPmXB_nM%252C_&usg=__t6C0TAgBPsLKydg3CEDF8s2Fwvg%3D Quote Link to comment Share on other sites More sharing options...
robertspark Posted November 25, 2014 Share Posted November 25, 2014 Wow, didn't realise that there could be such a large market for them, with the shear number of variants in the google image links .... one required for every tool box? Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 25, 2014 Author Share Posted November 25, 2014 OK, I guess that'll be next port of call then. Doesn't look too difficult when the plugs are already out anyway. Quote Link to comment Share on other sites More sharing options...
