stuck Posted November 27, 2014 Share Posted November 27, 2014 Evening. Can anyone recommend a quality timing strobe please? The plastic Gunson one I have is great as long as you have either three hands or an elastic band to wrap around the pickup shoe I don't need trick bits, just something that bloody works. Quote Link to comment Share on other sites More sharing options...
zim Posted November 28, 2014 Share Posted November 28, 2014 The snap on ones are really nice, but not cheap Hope you're well G Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 28, 2014 Share Posted November 28, 2014 I have the Gunsons Workshop Zenon light, nice heavy feel from metal case but TBH the main problem I have is getting the light in to a position where the light is on the marks and I can see them! Marc Quote Link to comment Share on other sites More sharing options...
stuck Posted November 28, 2014 Author Share Posted November 28, 2014 Thanks Chaps. Just been and emptied my pockets in the local snap-on van. Spendy. 1 Quote Link to comment Share on other sites More sharing options...
zim Posted November 28, 2014 Share Posted November 28, 2014 Just be careful using the advance / retard settings, from memory they're double (or is it half ?) due to the megasquirt spark system. G Quote Link to comment Share on other sites More sharing options...
stuck Posted November 28, 2014 Author Share Posted November 28, 2014 Cheers G, Seems a bit baffling at the minute. Can you remember which mode you use it in? Seems to offer DIS, Conv, COP, MSI-Conv & MSI-DIS what ever they are Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 28, 2014 Share Posted November 28, 2014 This is my understanding googling? DIS - Distributor less Ignition System Conv - Conventional COP - Coil Over Plug - mini coil on cyl head MSI - Multi Spark Ignition - fires more than once during ignition. So Megasquirt/Megajolt with Ford EDIS is DIS? In theory this setting should negate the halving of the values, but as Snap-On charge for a manual there is not an online version to see if this is the case? Marc. Quote Link to comment Share on other sites More sharing options...
stuck Posted December 1, 2014 Author Share Posted December 1, 2014 The snap on ones are really nice, but not cheap Hope you're well G G, Thanks for the recommendation. Used mine for the 1st time tonight & it's a superb piece of kit, almost worth the money Thanks for the info Sid Quote Link to comment Share on other sites More sharing options...
