Nigelw Posted December 6, 2014 Share Posted December 6, 2014 Whilst chatting with friends about tyres tonight we ended up at the old favourite "what pressure do you run yours at?". I run Cooper STT in 235/85 R16 On road, 30psi Off road, 18-20psi Got spme funny looks for that and then it sparked the hilarious debate about what is the optimum pressure for both on and off road without needing to adjust them constantly? I think it's just laziness but settled for 25psi being inbetween my own pressure settings, what does anyone else think? Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 6, 2014 Share Posted December 6, 2014 28-30 front 36 rear (unless towing) That's BFG AT 265/75/16 on or off road. Your pressures sound rather low, especially the rear, but I guess whatever works for you. I've found above make the 110 handle the best. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted December 6, 2014 Author Share Posted December 6, 2014 I like soft off road as I drive gently and want an increased footprint, the Coopers are a super stiff carcass!!! But they're not too hard on the road either, again I found the Coopers rather stiff, the rears are same as the fronts unless I am going to load it up or tow. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 7, 2014 Share Posted December 7, 2014 I read on an American 4x4 site where they said to draw a chalk line across the tyre tread - and go for a drive.. Then use the way it wears to tune your pressures. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 7, 2014 Share Posted December 7, 2014 I read on an American 4x4 site where they said to draw a chalk line across the tyre tread - and go for a drive.. Then use the way it wears to tune your pressures. That's what I was about to say..... if the line wears in the middle first you have too much pressure. Likewise, outside edges first means too little pressure. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted December 7, 2014 Share Posted December 7, 2014 Too low on the road effects mpg and handling and tyre wear. If you don't want to change them I'd run road pressure. Unless it's sand or rock crawling the bit of extra footprint may not make much difference and there are ways to get unstuck. Quote Link to comment Share on other sites More sharing options...
ToyRoverlander Posted December 7, 2014 Share Posted December 7, 2014 I run my 315/75-16 Micky MTZ on 16x7 rims at 22psi on the road and about 12psi offroad. Onroad it rides and handles well, offroad it's an animal. I reckon many people run way to high pressures on the road. Especially when they're still running bias ply tires like the cheap 7.50's which needs way less than a radial. Most of them wear out heaps in the middle. i had that happen to mine when I didn't knew better. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 7, 2014 Share Posted December 7, 2014 2.4 bar (35 psi) all round on my P38, both on the BFG ATs and GG AT²s. 1.4 to 1.5 bar (20ish psi) off-road. No settling on an inbetween pressure, use the optimal pressure for the road surface! Quote Link to comment Share on other sites More sharing options...
Team Idris Posted December 7, 2014 Share Posted December 7, 2014 I'm thinking it varies so much due to tyre type and weight, that the race track method of measuring it with a laser temp probe thing is the way to go. They seem pretty accurate, the price has dropped a whack over the years and you don't have to get dirty They measured left, middle and right. As well as pressure it said if the tyre needed to lean in or out more, but that's not really an issue on a beam axel. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 7, 2014 Share Posted December 7, 2014 I find you can fine-tune it pretty well by feel. Quote Link to comment Share on other sites More sharing options...
