Yay, I figured it out :)
I have been thinking about it for ten years, but I couldn’t get a workable ‘tube run’ that missed everything.
The idea is that a big roll feeds the mass of the engine and front axel into the roll bar. The bar has a bend so it isn’t a pokey shock load on the front hoop. Trees will ride over the cage better. The outriggers have less to do, as does the bolted in cross member that ties them together.
The chassis section can be reduced to bend the radius arm away from the tyre. (Max steering travel without wide rims and spacers)
Share this post
Link to post
Yep, it might work okay with enough bracing :D
I mean, it’ll work great as long as it doesn’t crumple up... Anyhoo, I haven’t had to butcher the truck to try it :)
Edited by Team Idris
Share this post
Link to post
Wow a long time ago :o 1992/3 maybe. Just after body removal and before hacking the rangy bits off the chassis.
edit; I think that is just after it was shortened by 14”. We kept the outriggers on to use as measuring points.
  • Like 2
Share this post
Link to post
It came out well for a hole saw and grinder part :)
basically an adapter to turn one master cylinder port into two.
  • Like 2
Share this post
Link to post
Posted (edited)
Yay, it didn’t fold up :) (and we tested it by failing to drive over a log)
It worked really well because yesterdays trial was very tight on width. The fiddle brakes are also working like they should and the ground was just right for them.
  • Like 1
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
