Eightpot Posted December 17, 2014 Share Posted December 17, 2014 Im just about to get on euro tunnel to calais and the alternator on the 2.5 n/a has thrown in the towel! Does anyone know where I can pick one up between calais/saint quinton?? Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 17, 2014 Share Posted December 17, 2014 Can't find anything useful as I type, however you could ring mm4x4 at martin hussingtree. and ask them to send on across to you if you are stopping out there for a bit. +44 (0)1905 451506 till 17:30 might just catch them Is is seized or is the diodepack gone? you might be better taking the belt off if it's seized and rigging something to run the waterpump. I had a bearing collapse in Rhyader one Sun and drove my 2.5nad back to mids with just the battery. careful use of battery on the diesel means you only really need to keep the stop solenoid open. Everyhting else is a load. I.e no big loads like lights/wipers/heater motor. You could cover a fair few miles if you can charge the battery up over night and drive in the day. Pete Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 17, 2014 Share Posted December 17, 2014 http://www.dgl-4x4.com Route d'Estourmel 59217 Carnières 03 27 78 66 80 Outside Cambrai, not sure if it's near the same Saint Quentin edit yup that should do it Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 18, 2014 Author Share Posted December 18, 2014 Well what a laugh- alternator destroyed itself within a few miles, took the belt out, no drive to waterpump, engine cooked leaving us in the pitch black at the side of the autoroutee with a flat battery. The only thing we had to try and make a fan belt with was the elastic waistband from my mates pants! (Doesn't work. .) Quote Link to comment Share on other sites More sharing options...
Giles Posted December 18, 2014 Share Posted December 18, 2014 That sounds grim... Is yr engine still ok? I THINK the alternator is an A127 unit also used on JCBs, Massey Fergusons and heaps of other stuff. They're pretty common and any decent depanneur should be able to sort it.... I'd say a well-stocked agri shop would have it on the shelf. Bonne chance, bonne route Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 18, 2014 Author Share Posted December 18, 2014 Nope, severe gasket failure, probably cracked head : ( Absolutely sh*gged! Quote Link to comment Share on other sites More sharing options...
