il-bob Posted January 9, 2015 Share Posted January 9, 2015 Hello, Yesterday I disconnected the maf sensor on the 4.6 GEMS to install a snorkel. Reconnected everything and for some odd reason, when starting it dies after a few seconds. If i disconnect the maf plug, engine will stay on. But if I switch off and re-connect the maf plug, it starts and dies soon after. The ecu light does not come on. I tried another used maf sensor but still the same. Any idea what might be the problem or what I need to check? These is voltage at the plug. Will it go to limp mode if I drive with the maf disconnected? Thanks, Rob Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 9, 2015 Share Posted January 9, 2015 It goes into some sort of backup plan without MAF. Could it be it's reading a totally different airflow because of the snorkel? Has it gotten dirty? Do you have access to diagnostic equipment so you can see the MAF readings? And reset fuel trims? Quote Link to comment Share on other sites More sharing options...
il-bob Posted January 9, 2015 Author Share Posted January 9, 2015 I had the OBD2 thing which I'll try tonight. Any will try to give the sensor a good clean Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 9, 2015 Share Posted January 9, 2015 Disconnected the snorkel and tried? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 9, 2015 Share Posted January 9, 2015 You haven't perhaps knocked the impact-sensor switch during your work, have you? I did this on my 90 when replacing the clutch M/Cyl some years back (impact switch is under the bonnet near the clutch master on a 90) and then spent a frustrating afternoon wondering why the £$(*%&£$%^$! thing wouldn't start. Quote Link to comment Share on other sites More sharing options...
il-bob Posted January 9, 2015 Author Share Posted January 9, 2015 Yes tried without snorkel but still doesn't dies with maf plugged in Quote Link to comment Share on other sites More sharing options...
il-bob Posted January 9, 2015 Author Share Posted January 9, 2015 Yes tried without snorkel but still dies with maf plugged in Quote Link to comment Share on other sites More sharing options...
Escape Posted January 12, 2015 Share Posted January 12, 2015 I'd trace the wiring from the MAF to make sure nothing has been damaged while installing the snorkel. Quote Link to comment Share on other sites More sharing options...
