dantastic Posted January 17, 2015 Share Posted January 17, 2015 I'm looking for the electric connector connecting to the fuel pump on a TD5. It's for a Defender 110. The connector is not in microcat and I think it's a BMW connector. any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2015 Share Posted January 17, 2015 Won't be in the parts book, as it would come pre fitted to the wiring loom, give PaulMc on here a shout, he's well up on recent LT plugs/sockets. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted January 19, 2015 Share Posted January 19, 2015 Hey Dantastic, if you find out let us know! I know most of the connections around the car are one variation of 'Econoseal' connectors or another. Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted January 19, 2015 Share Posted January 19, 2015 Full info courtesy of PaulMC in this post...not quite as easy as it would appear. Easiest solution is probably a TD5 disco scrapper... Matt Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 20, 2015 Share Posted January 20, 2015 Full info courtesy of PaulMC in this post...not quite as easy as it would appear. Easiest solution is probably a TD5 disco scrapper... Matt Further to my post in that thread, here are the BMW part numbers for the 4-way connector, terminals and wire seals - BMW connectors The 4-way connector housings are available from BMW dealers as – 4-way male housing – 61 13 8 367 075 (superceding – 61 13 8 367 071) 4-way female housing – 61 13 8 367 076 (superceding – 61 13 8 367 072) I can only find part numbers for unsealed terminals, the sealed ones only seem to be available pre-crimped to short ‘repair cables’, and then, only for up to 2.5mm2 cable. There is a 2.5 - 4.0mm2 female terminal listed, but no male terminal, that I could see – Female terminal, sealed, 2.5 - 4.0mm2 – 61 13 8 352 926 Wire seal for above – 61 13 8 352 924 The BMW part numbers for the unsealed male and female terminals to suit 1.0 – 2.5mm2 cable and 2.5 – 4.0mm2 cable, are – Male terminal, unsealed, 1.0 – 2.5mm2 – 61 13 1 376 193 Male terminal, unsealed, 2.5 – 4.0mm2 – 61 13 1 376 195 Female terminal, unsealed, 1.0 – 2.5mm2 – 61 13 1 376 204 Female terminal, unsealed, 2.5 – 4.0mm2 – 61 13 1 376 206 To connect to the TD5 in-tank pump/sender, you need a female connector housing and female terminals. . Quote Link to comment Share on other sites More sharing options...
Shackleton Posted January 20, 2015 Share Posted January 20, 2015 Fantastic, thanks a million Paul (and Matt). Quote Link to comment Share on other sites More sharing options...
dantastic Posted January 21, 2015 Author Share Posted January 21, 2015 This is brilliant info! Thank you very much! Quote Link to comment Share on other sites More sharing options...
stuck Posted January 21, 2015 Share Posted January 21, 2015 Tech archive? Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2015 Share Posted January 21, 2015 Tech archive? Link added to Tech Archive index in Electrical section. with same title as this thread. Quote Link to comment Share on other sites More sharing options...
