JB750 Posted January 17, 2015 Share Posted January 17, 2015 Anyone know the part number for the 8 flywheel bolts for the 300TDi? I've searched around on the internet but not having much luck. Apparently they are supposed to be replaced once removed and tightened to 146Nm Cheers. Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted January 17, 2015 Share Posted January 17, 2015 ERR4574 should be the one Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 17, 2015 Share Posted January 17, 2015 Yes, once used toss them away, when torqueing up the new ones do it in stages and in the sequence shown in RAVE. Don't forget to apply the correct type of Loctite to the threads. Quote Link to comment Share on other sites More sharing options...
JB750 Posted January 18, 2015 Author Share Posted January 18, 2015 I've been advised by someone else that they will be fine to re-use? Not sure what to do now Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2015 Share Posted January 18, 2015 Conftimed bolts ERR4574 x 8, workshop manual says use NEW bolts see attached at the green highlight line. new bolts already have pre aplied threadlock, so do not use anything else. Quote Link to comment Share on other sites More sharing options...
JB750 Posted January 18, 2015 Author Share Posted January 18, 2015 OK thanks. All I've got to do now is find somewhere to buy them without paying an arm and a leg..... Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted January 18, 2015 Share Posted January 18, 2015 From what I remember they are about £2.50 each Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2015 Share Posted January 18, 2015 OK thanks. All I've got to do now is find somewhere to buy them without paying an arm and a leg..... have a look at these supplier links Britcar Paddock LR Series Island4x4 LR Direct Craddock Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 18, 2015 Share Posted January 18, 2015 Yes. they are "special" because the untapped "land" portion of the bolt is an exact fit into the flywheel bolt hole so that they act as sideways (lash) location pins as well as retaining the flywheel onto the crankshaft. The price of Stirling 2.50 seem a tad high compared with our AUD$ but there you are, -- considering what they do I wouldn't advise you use anything other than genuine, a flywheel coming adrift isn't a pretty sight , I saw the result of a diesel generator set flywheel that did just that once and the hole in the building wall was quite impressive Quote Link to comment Share on other sites More sharing options...
teabag Posted January 18, 2015 Share Posted January 18, 2015 I've been advised by someone else that they will be fine to re-use? Not sure what to do now Don't believe all that u read in landyzone Quote Link to comment Share on other sites More sharing options...
JB750 Posted January 19, 2015 Author Share Posted January 19, 2015 Cheers guys. New bolts are on order now, seems a small price to pay for peace of mind. After all, I am spending a fair bit of cash and a whole lash of time on it this time so I might as well go for it! I just hope after all this that the damn thing runs for more than a couple of hundred miles without issue! Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 19, 2015 Share Posted January 19, 2015 you cannot have a Disco and a bank balance it simply doesn't equate. Quote Link to comment Share on other sites More sharing options...
