dioliahary Posted January 21, 2015 Share Posted January 21, 2015 Hi my hard top roof is damp, is this normal for a landrover or do i have a leak. It does seem like condensation but i am insure ta Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 21, 2015 Share Posted January 21, 2015 At this time of year probably condensation especially if you have damp/wet items in the car. Ours drips from behind the headlining down onto the dash but I have a known leak that makes the carpet wet. So yes it's more than likely normal. Mike Quote Link to comment Share on other sites More sharing options...
dioliahary Posted January 21, 2015 Author Share Posted January 21, 2015 Thanks, h Quote Link to comment Share on other sites More sharing options...
IanT90 Posted January 21, 2015 Share Posted January 21, 2015 Definitely condensation unless you're roof and side panels are well insulated and covered in trim. Even then you still get some build up. If you have side windows they can leak plus I had a s2a that leaked at the roof seal under the gutter cured it with silicone sealant. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 21, 2015 Share Posted January 21, 2015 I fixed that on my one by removing the headliner and gluing on some foil backed camping mats also fitted 25mm kingspan in the side panels. Cuts down damp & noise and also helps to keep the cab hot. Quote Link to comment Share on other sites More sharing options...
