(Another) I.R.D Question
Dezzie
Hi guys, my year 2000 L-series engine Freelander has been 'feeling a bit different' lately. :wacko:
If my I.R.D unit was failing, how would I know ? What kind of noises would it make or how would it drive?
If my I.R.D does fail, would the vehicle still work in 2 wheel drive with the prop removed ?
Thanks for any replies................. Matt. :D
Check the VCU by driving the car in a tight circle on hard ground and the car should drag a little bit, but the rear wheels shouldn't skip. If you're in any doubt at all, take the propshaft off before the IRD box gets damaged too badly. The car will be fine without the prop as long as theres no metal chunks in the oil.
Best thing to do is drop the oil out of the IRD unit and see if there's any metal fragments or a sheen about the oil.
  • 2 weeks later...
