DiscoHere Posted February 9, 2015 Share Posted February 9, 2015 Hi all One of the UJ's on the double UJ on the front prop shaft is gone on my Disco TD5. Do i need to know anything special before i tackle its replacement. I also presume i need to replace both joints at the one time. While i am at it do anyone know the location of the outside temperature sensor. I am fairly sure mine is reading incorrectly. And can anyone tell me the size or measurement of the blocks used on the bump stops to re calibrate the suspension air bags Thats enough for now Hugh Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted February 9, 2015 Share Posted February 9, 2015 As long as the centre brg in the double cardon joint is ok, changing them is straight forward, but painful to get the centre lump orientated. The other end is easy. Paul 2001 td5 Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted February 14, 2015 Author Share Posted February 14, 2015 I opted for the simple solution ...........replace the entire shaft. Quote Link to comment Share on other sites More sharing options...
