jackmac Posted February 10, 2015 Share Posted February 10, 2015 Noticed that my panhard rod bushes had some play in them a while back, so I finally got round to replacing them today. Wish I hadn't started! First problem was that quite a bit of the play is actually being caused by the holes in the axle mount being oval shaped, so I can move the bolt around in there quite easily. Is there anything I can do to remedy that? (other than replace the axle casing) Second problem... the new bushes don't fit! I bought some polybushes as replacements, and they are way too small. Part number ANR3410 on the bag, when I went to fit them they just fell straight through the hole... Is there a different part number I don't know about? Or have I just been sent the wrong part? Quote Link to comment Share on other sites More sharing options...
jackmac Posted February 10, 2015 Author Share Posted February 10, 2015 Just seen this excellent post: http://forums.lr4x4.com/index.php?showtopic=55599 . So that solves the first problem, just need to nip down the the local garage once I have it all on to get some washes welded on. Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2015 Share Posted February 10, 2015 your new bushes should look like these, same part number http://www.lrseries.com/shop/product/listing/2958/ANR3410-BUSH-PANHARD-ROD.html I fitted Superpro bushes to mine, oil/grease resistant. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 10, 2015 Share Posted February 10, 2015 Personal preference.... Bin the polybush and go genuine..... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 10, 2015 Share Posted February 10, 2015 go genuine rubber. Welding the appropriate sized washers over the elongated holes will solve the issue. Quote Link to comment Share on other sites More sharing options...
jackmac Posted February 11, 2015 Author Share Posted February 11, 2015 Right... I've done some measuring. I have 2 sets of panhard rod polybushes, different manufacturers, both ANR3410. They both measure around 29.5mm outside diameter. The hole for the bush to go into on my panhard rod measures 35mm inside diameter. Not surprised I'm having problems!! I think I must have a panhard rod from a post 2002 (possibly post 2007?) defender, which has a larger bush? Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2015 Share Posted February 11, 2015 according to the part number info I have access to. upto 2007 --------- bush ANR3410 use M14 bolt below or RBX101340 use M18 bolt below bolts M14 X 80mm long -- BH114167 M16 x 82mm long -- RYG501560 2007 on use the Bush RBX101340 & Bolt M16 x 82mm long -- RYG501560 HTH Quote Link to comment Share on other sites More sharing options...
jackmac Posted February 11, 2015 Author Share Posted February 11, 2015 according to the part number info I have access to. upto 2007 --------- bush ANR3410 use M14 bolt below or RBX101340 use M18 bolt below bolts M14 X 80mm long -- BH114167 M16 x 82mm long -- RYG501560 2007 on use the Bush RBX101340 & Bolt M16 x 82mm long -- RYG501560 HTH Excellent info as always, thank very much!! Didn't think to measure the bolt, i'll do that saturday then pick up the right bushes (hopefully!) at Donington on Sunday Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2015 Share Posted February 11, 2015 your welcome, Quote Link to comment Share on other sites More sharing options...
