dioliahary Posted February 11, 2015 Share Posted February 11, 2015 Hi i purchased a a frame for the bumper bar but for the life of i cannot figure out what these do or go, any ideas? Sorry trouble loading the photographs hopefully here they are, the knurled bar and the bent bracket, the picture shows where it goes but for the life of I cannot figure it out Quote Link to comment Share on other sites More sharing options...
dioliahary Posted February 11, 2015 Author Share Posted February 11, 2015 Here's the knurled bar with the instructions looks like it attaches to the jack! But why when it is part of a bumper a frame bar kit. Enclosed is also a picture of the a frame Quote Link to comment Share on other sites More sharing options...
dioliahary Posted February 11, 2015 Author Share Posted February 11, 2015 Phonies attached Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 11, 2015 Share Posted February 11, 2015 I'm no expert here but my guesses are..... Bent brackets should bolt into the bottom of each side of the Frame... These look like they will be the anchor point to match up to the brackets you are attatching to the bumper bolts & chassis. And as you will be extending the gap between front of car and the jacking holes in the end of the chassis legs, I assume that the knurled bar is to extend the reach of the jack.... Quote Link to comment Share on other sites More sharing options...
dioliahary Posted February 11, 2015 Author Share Posted February 11, 2015 Ahh the jack attachment now makes perfect sense, will investigate the relationship with the bracket.. Quote Link to comment Share on other sites More sharing options...
dioliahary Posted February 11, 2015 Author Share Posted February 11, 2015 After some scrutiny i think the brackets are not completely matched to the a frame...but a little fekling should sort it out. Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 12, 2015 Share Posted February 12, 2015 brackets might go inside the bumper, hence not matching to compensate for the thickness of the bumper steel between. if you just bolt it thru the bumper the thin bumper steel will deform as soon as load is put on it (some clever attaches a tow strap to the top of your A-frame coz then he doesn't have to bend down..... don't laugh... have seen it done and then wonder "why it broke") so anything that works on your bumper will always need some sort of load spreader on the bolts. Quote Link to comment Share on other sites More sharing options...
