bodumatau Posted February 12, 2015 Share Posted February 12, 2015 Hello all I am busy planning my megasquirt installation on my 3.5 efi, my current air filter setup is a PROPER bodge. with a flatbar bent homemade bracket coming off the firewall and barely missing the brake lines then barely missing the fuel lines to then barely hold the air filter up so with Nige's setup I can get rid of the flapper (probably make a good boat anchor) AFM, which is currently mounted to the back of the V8 with a flatbar bracket off one of the bell housing bolts. my landy is a LHD so I have the brake servo limiting my space on vehicle left of the engine. so my idea is to put a 90 elbow off the plenum, then the AFM from Nige, then another 90 elbow to the air filter mounted at the back of the V8 does anyone have pictures or know the correct bracket I need to mount the air filter to the back of the V8? (don't the carb V8's have their air filter at the back? here a pic of my current bodge setup. and here what I would like to do any ideas or tips would be welcome Quote Link to comment Share on other sites More sharing options...
rrr47 Posted February 12, 2015 Share Posted February 12, 2015 Can you mount the plenum chamber on backwards so the air inlet is on the other side, your passenger side? I have seen them pointing to the left, you appear to have more room that side. Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 12, 2015 Author Share Posted February 12, 2015 I have considered this but there are so many little bits that I would then have to change, don't know if it is worth it, there is enough space for my pipes to get past the servo, just not enough to do much more than that. Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 12, 2015 Share Posted February 12, 2015 You can get the original brackets from LR. Just make sure you're sitting down before asking for the price. Im not near my pc that has allbrit saved on it, but if you look on there, or retroanacondas partsbook pdf, you will find the part numbers. Hth Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 13, 2015 Author Share Posted February 13, 2015 does anybody out there have photos of the V8 air filter mounting ? rgds Heiko Quote Link to comment Share on other sites More sharing options...
