Window fillers
Mutley
 Share
How easy is it to remove all the window filler bits on the drivers and passenger doors? I have looked at the parts section and it does not show they are fixed with anything, so do they just pull out to remove then push back in place??? Also cant find any info part numbers for the felt bits? As this is going in for a re-spray would like to remove as much as possible, sadly will not be able to take it all to bits as I have to drive it there and back.
Soooooo NOT looking forward to removing windscreen though!!!!!!!!
Very small countersunk self tapper screws go into the window channel slides and hold the lot together... Tip: get a narrow screw driver and slowly run it down the window slide and you'll pick them up. With screws removed they just come out with a gentle pry.
 Share
