Carl&trish Posted February 16, 2015 Share Posted February 16, 2015 Hiya all I'm having issues with my 98 discovery 300 tdi immobilizer it doesn't have the black box behind stereo I found after buying the connector to bridge it ... I don't have the chipped key and car was running fine before I found a couple of blown fuses and replaced them I now have immobilizer lights on dash , I found out on here about bridging terminals 10-11 in the green box in alarm modul and it now turns over but won't fire up . My question is does anyone know how to bridge the fuel pump it's the 3 wire type " pictures would be useful if anyone has them " Thanks in advance Carl Quote Link to comment Share on other sites More sharing options...
Carl&trish Posted February 17, 2015 Author Share Posted February 17, 2015 All sorted and hope this helps other it's a very easy fix " well I thought so " The ecu on the back of the diesel pump has to be remove " smashed off " sorry no better way of putting it once removed there will be 3 wires that used to goto the ecu disgard 2 of those so your left with just the black then simply connect that to the black wire coming from stop solinoid , Quote Link to comment Share on other sites More sharing options...
hangover Posted February 22, 2015 Share Posted February 22, 2015 You have an EDC equipped D1 which we didnt get in Aus, i still have a semi issue with mine in that the immobilizer is still preventing normal power to the inj pump so i have ben using a work around for the last 3 years, i might have to bite the bullet and buy a new alarm- My D1 is 01/98 build. Quote Link to comment Share on other sites More sharing options...
