Sandy Landy Posted February 17, 2015 Share Posted February 17, 2015 Does anyone know the difference in rate between the RBK500300 and the RBK101111? I have the RKB101111 rear, and std front (300tdi), and it is still quite firm, not ridiculous but I wouldn't mind it softer. Incidentally I have noticed a ride improvement when I had to renew the rear bottom shock bushings, (they are now superpro) I think they take a bit of punishment at the back. I think two of us posted links to the spring rate charts in this thread, look though the posts and you will find them and all the rates and general spring information. Quote Link to comment Share on other sites More sharing options...
Sandy Landy Posted February 17, 2015 Share Posted February 17, 2015 Here it is http://rovers.red90.ca/springinfo.html Quote Link to comment Share on other sites More sharing options...
chris200100 Posted February 17, 2015 Share Posted February 17, 2015 I'm not sure of the rate for the rbk500300 as they are the lastest spec ones for a County and not on that list. I had them fitted on my last defender and there were great. One thing with springs if you just want standard hight buy genuine parts only they arnt much more than aftermarket and last ages. Quote Link to comment Share on other sites More sharing options...
wanger Posted February 17, 2015 Share Posted February 17, 2015 what about the dampers? Quote Link to comment Share on other sites More sharing options...
Sandy Landy Posted February 18, 2015 Share Posted February 18, 2015 So...... Who is going with what? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted February 18, 2015 Share Posted February 18, 2015 Yes, I was very familiar with the spring chart, it was simply that RBK500300 isn't on it. Quote Link to comment Share on other sites More sharing options...
Bish66 Posted March 24, 2015 Author Share Posted March 24, 2015 Get the front rubber tower isolation items...OEM items, should be 8 pounds each in cost...they isolate GREAT...rear ones are even cheaper! Does anybody have part number for front and rear isolation items for a 110??? Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted March 24, 2015 Share Posted March 24, 2015 Slightly unrelated question but my 90 is a HT would this have different springs to a CSW of the same vintage? At the moment it gives quite a harsh ride as it isn't used very often for heavy loads. I've bought 8 spring isolators to fit top and bottom to see if they offer a bit of an improvement. Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2015 Share Posted March 24, 2015 Yes, I was very familiar with the spring chart, it was simply that RBK500300 isn't on it. not on the spring list because that LR part number is these [not springs] http://www.lrdirect.com/RBK500300-Kit-Steering-Gear-Tie-Rod-Re?gclid=CN2y-LLjwcQCFQyWtAodW0MAUA Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 25, 2015 Share Posted March 25, 2015 Good catch! A bit of finger trouble.The correct number is RKB500300; the TD5 and non-CSW number is RKB101111. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted March 26, 2015 Share Posted March 26, 2015 lots of lucky dip going on here. IMO start by weighing the truck and front and rear axle weights. Figure out your current rate accurately and dial in from there. How hard is it to get custom coils wound in the UK? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 26, 2015 Share Posted March 26, 2015 Not hard, but you may as well just buy some properly specced OME springs, they normally have stuff in the right ball park. Quote Link to comment Share on other sites More sharing options...
Bish66 Posted April 2, 2015 Author Share Posted April 2, 2015 Well a little update is in order. I ordered the following set up in the end: NRC8044 and NRC8045 for the front. I eventually plumped for for RBK500300 as it is a little softer and little taller (uncompressed) than the RBK1001111. The ride is greatly improved and much less crashy. I am almost tempted to say that it is now comfortable and am looking forward to seeing what it will ride like with a little weight in the back. I can honestly say that this is a very good set up and came in pretty cheap from Dan at Duckworth parts - I only ever use original parts, call me mad but I feel they are the best!! Thanks for all your help guys! Bish Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 2, 2015 Share Posted April 2, 2015 Good to hear how it went and that it worked out well. Is it a little high at the rear, or do the springs compress once fitted? I'm very interested because I have the RKB1001111s (bought before RBK500300) and although I can get my 90 in the garage I can't get the 110 in - 15-20mm would make all the difference. This is with almost flat rear tyres. Quote Link to comment Share on other sites More sharing options...
