dangerous doug Posted February 18, 2015 Share Posted February 18, 2015 My 200tdi 110 keeps blowing fuses for the hibeam flash/horn. Is this a common fault and does anyone know where I can start fault finding? Everything else works ok Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 18, 2015 Share Posted February 18, 2015 Check the stalk there's a cable that goes up the centre that can rub through and short on the stalk. Mike Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted February 18, 2015 Share Posted February 18, 2015 Blowing both sides at the same time? Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 18, 2015 Share Posted February 18, 2015 Had this on my 300 tdi turned out to be worn cable running from the horn and lights along the back of the front wing, pain to get access to but worth a look at if you cant find anything at the stalk end. Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 18, 2015 Share Posted February 18, 2015 From the fuse box, do a continuity check to earth, you should be able to work out what side of the fuse box the fault is... Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted February 18, 2015 Author Share Posted February 18, 2015 Thanks for the replies. I'll have a look Quote Link to comment Share on other sites More sharing options...
