Hazard lights aren't working, yet indicators work fine? LED units
Hello all, just got my first defender, a 1999 td5 90, and i think its brilliant!
It has LED indicator lights and has and an rdx relay, that makes them flash at the right speed.
Right and Left indicators work perfectly, but when I switch on the hazards there is nothing happening. Any ideas on what might be causing this?
I think ill just buy a new hazard switch n try that first.
The only other thing electrical that doesn't seem to work is the interior light doesn't come when you open the door, yet it works on the switch... but i don't imagine these problems would be linked?
As you can probably guess my electrical knowledge is limited!
That'll likely be the switch at the door. These can be tempermental.
The indicators work from ignition feed and hazards direct from battery, each feed is on a different fuse, so its possible to blow the fuse that feeds the hazards and leave the indicators working
  • 4 years later...
