skauldy Posted March 1, 2015 Share Posted March 1, 2015 Guys, Fitted 35" tyre to my def 90 and general census is to fit raised suspension. Going to get some pro comp +5" shocks but question is can I still use my standard turrets or do I have to fit - or + 2" shock turrets. Shane Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 1, 2015 Share Posted March 1, 2015 With standard turrets you will gain the 5" in suspension drop - a lot of dislocation (assuming the rest of the set up will flex that much). If you go for +2" turrets you will get 2" more compression travel and 3" more drop. A better plan in my eyes. Quote Link to comment Share on other sites More sharing options...
skauldy Posted March 1, 2015 Author Share Posted March 1, 2015 Cool. Will go for that so. Read up on it but just couldn't get my head around it. Thanks anderzander Quote Link to comment Share on other sites More sharing options...
Frax Posted March 2, 2015 Share Posted March 2, 2015 I run 35's for years on +2 shocks and turrets, the only downside was it was not very good when towing. Moved down to 33's in the end. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted March 3, 2015 Share Posted March 3, 2015 Guys, Fitted 35" tyre to my def 90 and general census is to fit raised suspension. Going to get some pro comp +5" shocks but question is can I still use my standard turrets or do I have to fit - or + 2" shock turrets. Shane This all depends what you want to actually achieve from the suspension. For starters: -Why do you feel the need to fit "raised" suspension? Do the 35's rub? -Fitting longer shocks is not a suspension lift. Quote Link to comment Share on other sites More sharing options...
