CR88 Posted March 2, 2015 Share Posted March 2, 2015 Hi, Before presenting my question I would like to mention that I made a search to find a similar topic without success. I have a 200 tdi, from a RR w/o AC. My idea is moving the alternator from the original position to AC location, an obvious solution when installing a second alternator. The issue over here, is which pulley I should use, since I found no free pulley. Which pulley I should use? Can you give me some tips, since I made a search for similar images and so far no luck at all. Thanks, CR Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 3, 2015 Author Share Posted March 3, 2015 Found the info necessary here: http://www.gwynlewis4x4.co.uk/wp-content/uploads/2014/05/200tdi-Disco-Alternator-Mount-Fitting-Instructions.pdf Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 3, 2015 Share Posted March 3, 2015 Sorry I missed this earlier, but this is also an option for your pulley http://www.paddockspares.com/err3093-pulley.html?gclid=Cj0KEQiA1NWnBRDchObfnYrbo78BEiQA-2jqBWF3QOjvw1_VBXm5sCg2Rfdrg8yXlBFeUGa9RVMDliAaAhAc8P8HAQ it is a 3 groove pulley and actually cheaper than the twin groove counter part! Quote Link to comment Share on other sites More sharing options...
