blueski Posted March 7, 2015 Share Posted March 7, 2015 P0300, P0301, P0303, P0304 did a full tuneup the problem still the same , same code ..running very poorly . The power just dropped off and now it idles very poorly and loud . It cannot be driven also P1472 and P1471..replace both VIS code no longer present ........the freelander also engine service light on and a flashing oil light ..after 50 MPH the car shake a lot . cylinder #5 spark pug had oil on it when I pulled out ,,,, also has a thermostat leak .........do I need a new engine?? Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 8, 2015 Share Posted March 8, 2015 Have you tried putting new plug in #5 , also have you checked that #5 is actually sparking . Have you done a compression test on #5 ? What is your location ? Quote Link to comment Share on other sites More sharing options...
blueski Posted March 8, 2015 Author Share Posted March 8, 2015 yes new plug and coils.....location nj,, no compression test ,,, Quote Link to comment Share on other sites More sharing options...
blueski Posted April 11, 2015 Author Share Posted April 11, 2015 did my compression test ....pass ..what else do i have to look for a misfire? Quote Link to comment Share on other sites More sharing options...
