Mutley Posted March 10, 2015 Share Posted March 10, 2015 Have a 300tdi with the rectangle box lights for fog and reverse, is it simple enough to change to the round Td5 type ie cut wires, conect cut wires to new light fitting conectors and jobs a good un, or is there more to it? Cheers Mutley Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 10, 2015 Share Posted March 10, 2015 the wiring is same , I feed 1 earth . the rectangular lights are surface mounted with two screws . So shouldnt be a technically challenging swap JMHO Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 10, 2015 Share Posted March 10, 2015 Exactly as you said it, Mutley. I can't remember if the fixing studs are in slightly different positions - I have a vague recollection that they are diagonally opposite, not horizontal like on the rectangular lights. Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2015 Share Posted March 10, 2015 you will have to make a bigger central hole for the bulb holder to sit through the panel, http://www.lrseries.com/shop/product/listing/2844/AMR6524-REAR-FOG-LAMP-ASSY.html?search=rear%20fog&page=1 http://www.lrseries.com/shop/product/listing/2842/XFE500010-REAR-FOG-LAMP-LATE-TYPE.html?search=rear%20fog&page=1 or buy led versions that are fully sealed & surface mounted. Quote Link to comment Share on other sites More sharing options...
Mutley Posted March 10, 2015 Author Share Posted March 10, 2015 Ok think i'll go with the Td5 round lights, i mean how hard can it be ? Plus the old box ones crumbled and fell to bits when i took them off this afternoon!!! 1 Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted March 18, 2015 Share Posted March 18, 2015 Think it is the TD5 ones I have. I doubled up with one of each per side. Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2015 Share Posted March 18, 2015 I doubled up my rectangular versions when I found both sets of wiring on each side. Quote Link to comment Share on other sites More sharing options...
