Billy3334 Posted March 16, 2015 Share Posted March 16, 2015 Help I hav a defender 90 with puma engine, wen it's started up its got a loud knocking noise, seems to be under injectors, 07 plate , wen it's revved up it goes away abit, not smoking, powers still there. No lights on in dash. Can anyone help , many thanx andy Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted March 16, 2015 Share Posted March 16, 2015 Could be the infamous cooling jet issue that affected early Puma 2.4's. This is a known issue and land Rover where at one time replacing engines where owners had reported knocking on startup: I'm not saying this is 100% your problem as you will need to check your engine or VIN number and cross reference. More info in this thread http://forums.lr4x4.com/index.php?showtopic=30857 Quote Link to comment Share on other sites More sharing options...
landy andy. Posted March 17, 2015 Share Posted March 17, 2015 Possibly a failure of the VCV on the fuel pump. Easy to change, costs about £120, but requires recalibration. Andy Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted March 21, 2015 Share Posted March 21, 2015 is the noise just as it starts or all the time at tickover? Does the rattling have a rhythm? Slight possibility that timing chain tensioner/chain, is out of adjustment if the engine has fairly high miles allowing the chain to rattle around a bit. Quote Link to comment Share on other sites More sharing options...
